Tri-Pac questions
Discussion in 'Ask An Owner Operator' started by RedBeard, Apr 23, 2011.
  1. RedBeard
    RedBeard Medium Load Member
    331
    421
    Jan 12, 2006
    Marianna, FL
    I have a Thermo-King Tri-Pac APU on my truck. For a few weeks now, when I would first start the APU, it would run fine for a few seconds, then bog down when the A/C compressor kicked on. I could stop it, restart it, and it would run fine. Today, I started it, and it's blowing hot air. The compressor won't kick on, though the fan on the condenser mounted on the back of the cab will run. I'm figuring it's been low on refrigerant for a while now, and finally got low enough to not run the compressor. I have a big canister of R-134a and the gauges/hoses to charge it (and a squjirt bottle of soapy water to find a leak), but can't seem to find where to put the refrigerant in. I'll be taking off the lower cover and looking in the area of the compressor tomorrow, but figured I'd ask if anyone here knows offhand where to put the refrigerant in. Also...it does use R-134a, right?
  3. Ukumfe
    Ukumfe Medium Load Member
    301
    515
    Oct 23, 2008
    These guys created the Tri-Pak and sold it to Thermo King. I would bet they could answer a lot of your questions. The one in DePere Wi. but any dealer I would think could help.
    http://www.thermokinggreenbay.com/showcaseproductdetail.htm?ID=1497&Used=1
    I am not sure what type of refrigerant it requires, but you can check the level of it if you can get the compressor to kick in. Follow the lines from the condenser to the black cylinder. ( dunno what it is called ) Top of this is a "window" inside it is the refrigerant. A Thermo King shop told me that you can see a bubble pass through this "window" when the compressor goes on and off. While it is running you should see nothing, meaning it is full and you are seeing the referigerant passing by. Maybe if you are seeing multiple "bubbles" means it is low. Anyway you need to get the compressor running to at least verify that. Good Luck!!
  4. RedBeard
    331
    421
    Jan 12, 2006
    Marianna, FL
    Thanks, I'll give them a call. I know with regular automotive A/C, once it gets very low on refrigerant, the compressor won't kick on until more refrigerant is added. This is a function to protect the compressor, as the refrigerant also carries with it the compressor lubricant. No refrigerant = no oil to compressor = burnt up compressor fairly quickly.
    So I will likely need to add refrigerant to get the compressor to kick on. I could find out for sure, if I could hook my A/C service gauges to the low pressure fitting. Just gotta find the fitting ;-)
    If I don't find it by Monday, I'll give those guys a call. I figure I also want to get my hands on a technical manual for the thing, too.
