Tries to start when shut off
Discussion in 'Freightliner Forum' started by ibj50, Jan 14, 2017.
  1. ibj50
    ibj50 Bobtail Member
    2012 Cascadia. If the power switch is not shut off when engine is shutdown it will randomly start cranking the motor for a few seconds and then stop for some minutes and then try again. It has burned up the small solenoid on the top of the starter. We have replaced the relay in the glove box and it went for a couple of days without doing it but has begun again. We bought a cable tracker but in reading the directions not sure we can use it without unhooking a bunch of connectors from the sam cab, anyone have experience using one of these to track down shorts or ?
  3. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    Water intrusion into the Sam Cab module will cause this...they incorporated a plastic sheet over the top of it to prevent water from a leaking windshield seal to collect in the module. This scenario has also caused some "thermal events" on unoccupied trucks.
    magoo68, ibj50 and mhyn Thank this.
  4. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    thermal events !!!!!!!!!!! liked it !!!!
    magoo68 Thanks this.
  5. ibj50
    Do you know if the plastic sheet is available as an add on for the earlier models?
  6. Ridgeline
    22,724
    123,397
    I would hazard to guess that anything that can deflect water off the unit will work.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    They will fit, help and are more like an upside down bowl.
  8. Chubbytruckers
    Chubbytruckers Bobtail Member
    I have a similar problem with my 1996 freighliner fld 120 it keeps attempting to start on its own .... should I look for the same solution the Sam cab module?
