tripac room temp-sensor problems
Discussion in 'Ask An Owner Operator' started by pbrstreetgang, Feb 15, 2021.
  1. pbrstreetgang
    pbrstreetgang Light Load Member
    192
    26
    Sep 7, 2007
    California
    (2009 thermoking tripac with espar bunk heater)
    Where is THE REAL room temperature sensor? are there 2 sensors in different locations running at the same time that interfere with each other??
    the room temperature sensor for these older Thermo king units is supposed to be the shiny rod-looking thing sticking out of the bottom of my control unit. My Thermo king unit seems to work OK in the summer, spring, fall, and in winter’s warmer days..... but when it gets super cold, my bunk heater comes on full blast no matter how warm it is inside the truck. In other words, toasty warm in the truck but the heater is still blasting and then I get WAY too warm. (temp set to 50, which is the minimum setting). It’s almost like during these colder days the room temperature sensor is located outside the truck where it’s actually cold.
    I bought a brand new temp sensor and replaced the old one, and it makes no difference… I still get blasted with heat. I even took this supposed temp sensor and ran it down in front of the heater to warm it up (the tip) and it does NOT make the heater turn down! Not only am I way too warm but also I’m afraid I’m gonna burn out my heater fan and my heater fuel pump
    any ideas??
  3. Hye
    Hye Bobtail Member
    46
    24
    Jan 23, 2021
    Well most likely its located in display box. If its not there then follow the cable that goes out from display's board. On the board you will see a mark saying temp sensor. I am talking about sensor that is related to cooling a/c mode.
    The heaters sensor can be a. In unit, b. In heater's control box. If your heater control box has a display showing degrees than the sensor is located in there.
    pbrstreetgang Thanks this.
  4. pbrstreetgang
    192
    26
    Sep 7, 2007
    California
    OK I was told today the temperature of the air going into the intake on the heater will help determine when it decides to stop blasting hot air. My heater is located under the bunk where it is always very cold even when the rest of the truck interior is warm… So I need to run tubing from the intake of the heater to the main part of my truck interior where it is warmer, if that makes sense. So it’s not just the control panel Temp sensor in other words… Anyway thanks
    77fib77, skallagrime and Hye Thank this.
  5. skallagrime
    skallagrime Road Train Member
    3,855
    9,928
    Apr 10, 2012
    Indiana
    Quick and dirty for that would be aluminum dryer vent hose and some foil tape.
  6. 86scotty
    86scotty Road Train Member
    4,728
    12,989
    Aug 27, 2017
    Appalachia
    Be careful here, don't carbon monoxide yourself with jerry rigging it. Just drop by a TK location and ask.
    Mine has the dial, not digital. Sometimes I have to turn it almost down to cold (blue) to get the furnace to cycle down some. Other times I've got to put it to 3/4 in the red to get it warm in here. They are funny sometimes.
    pbrstreetgang and 77fib77 Thank this.
  7. 77fib77
    77fib77 Road Train Member
    11,717
    77,480
    Jul 7, 2010
    St Louis
    This makes sense. My espar heater cooked me the other night when it was 2 'F. I opened the wing window.
    Cutting a vent to the where bunk heater lives, so you get done circulation into the space under the bed? Or it's going to spring in three weeks....
  8. pbrstreetgang
    192
    26
    Sep 7, 2007
    California
    77fib77 yeah this is basically what i did, cut a vent i can easily fill up when it gets warmer. works great...heater doesnt blast me anymore
    77fib77 Thanks this.
  9. pbrstreetgang
    192
    26
    Sep 7, 2007
    California
    egr truck...it's done way worse to me than this
  10. pbrstreetgang
    192
    26
    Sep 7, 2007
    California
    good idea and i would have done this except it's so cramped under the bunk that just venting isnt going to lose me that much. theres like 4 cubic inches of air under the bunk cuz ive got so much stuff there. if there was tons of empty space and i was worried about the extra heat id lose, id do this
  11. skallagrime
    3,855
    9,928
    Apr 10, 2012
    Indiana
    Thats part of your problem Id wager. Your stuff is probably blocking the normal path the heat would have taken to get out from under the bunk. My ac/heater core unit in the back burned up a motor because it didnt have the open space for its intake to function correctly
