trouble Changing gears
Discussion in 'Mack Forum' started by Dwightsch, Feb 8, 2015.
  1. Dwightsch
    Dwightsch Bobtail Member
    14
    I have a 98 mack ch with 427 and a 13 speed Im having trouble with the transmission not wanting to change smoothly from high range back down to low it either grinds and goes in hard or you have to come to a complete stop makes it hard when you are in a binding pull with a load of gravel or pulling a back hoe
  3. poppapump1332
    poppapump1332 Road Train Member
    2,986
    2,464
    Jan 2, 2010
    birdsboro,pa
    My guess is back of transmission needs rebuilt
    Badmon, Dwightsch, 201 and 1 other person Thank this.
  4. EHB
    EHB Medium Load Member
    491
    209
    Apr 26, 2011
    Newfoundland
    Are you dubbing clutching, if equiped is the cluching fluid up and when was the last time the clutch was replaced. Could be the throw bearing wore out also.
  5. 201
    201 Road Train Member
    12,851
    26,450
    Apr 16, 2014
    high plains colorado
    Dwightsch Thanks this.
