Truck built for speed
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Dec 12, 2020.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,416
    1,739
    Dec 4, 2019
    What is the best transmission and rear end combination, for hills and flat country? 80-90Klbs range gross. Gonna be in a 25-40 year old truck.
    truckdriver31 Thanks this.
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    short legs for pulling, long legs for running. with that rate. i would say low pro 22.5 and 3:55 legs
    lester Thanks this.
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Depends on era of engine. Best to follow engine manufacturer gearing recommendations. What engine we talking?
    The Veteran, A5¢ and 650cat425 Thank this.
  5. okiedokie
    okiedokie Road Train Member
    13,931
    110,477
    Jun 13, 2011
    PNWET
    Big horsepower & long legs. Making mts into mole hills.
    Coffey, mile marker 27 and 650cat425 Thank this.
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    3.70s tall rubber and you got a triple digit truck
  7. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    100 mph with 3.70s you're gonna be screaming to hit 100
  8. 062
    062 Road Train Member
    6,333
    33,973
    Oct 20, 2013
    Calculator says 2075rpm with .73 top gear.
    Brettj3876 Thanks this.
  9. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    It does depend on the engine but my vote would be 390 Rears.
    They are low enough to give you the grunt to pull up the hills but they're high enough that you can Cruise.
    With 390 rears at 65 my truck is turning about 1550 or so.
    At 80 miles an hour not sure about rpms, but I still have plenty to go.
    Now if you are out west and the speed limit is 75 where you often travel and you want to cruise at 80, you probably want to be geared a little bit higher or maybe have a double Overdrive.
  10. 062
    6,333
    33,973
    Oct 20, 2013
    The other option is to put in a auxiliary.
    alds Thanks this.
  11. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    The truck im my avatar has Lo Pro 22.5 and 3.91s behind an old school .62 dbl over. According to gear calc i can do 103.13 at 2100 LOL
    singlescrewshaker Thanks this.
