truck cab vibrations
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dorsey, Mar 7, 2015.
  1. Dorsey
    Dorsey Medium Load Member
    412
    209
    Jan 28, 2012
    Florida
    What all can cause the truck cab to vibrate. Mostly under acceleration. It just started this the last couple of days.
  3. RSQ20
    RSQ20 Medium Load Member
    do you have an engine miss fire, or a bad engine mount?
    Check the Ujoint at the transmission output..
    .... Philip
    Dorsey Thanks this.
  4. PaulE
    PaulE Medium Load Member
    413
    145
    Jan 15, 2009
    Verona Wi
    Bad engine mounts, broken cross members , carrier bearing . ride height etc,etc. long list
    Dorsey Thanks this.
  5. xsetra
    xsetra Road Train Member
    5,198
    7,148
    Aug 21, 2011
    bad tire, out of balance.
  6. Dorsey
    412
    209
    Jan 28, 2012
    Florida
    I checked the ujoints. Where the drive shafts slides back and forth wiggles a little. I dont know if that is normal. The carrier bearing has a rubber price on it? I can make that move. Normal? As far as the truck having a miss fire. I know this sounds stupid but you really can't tell with the vibration. It still pulls good. That's why I asked earlier on another thread about how to check for codes. Nothing for codes though other that the 55.
  7. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    The rubber moving is normal. It's there to absorb the movement of the ujoints at that location. The slip joint moving is not normal. There shouldn't be any play there at all. It should only be able to slide forward and backward within itself
    Dorsey Thanks this.
  8. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    is it Cascadia dd15 ?
  9. Diesel Dave
    9,701
    33,076
    Jan 20, 2010
    Hesperia, Ca.
    I think you found your problem.............the slip yoke is not suppose to wiggle. Many forget to grease this and it dries out.
    Dorsey Thanks this.
  10. Dorsey
    412
    209
    Jan 28, 2012
    Florida
    No. It's a 2007 379 with a c15.
  11. Dorsey
    412
    209
    Jan 28, 2012
    Florida
    I stopped by a shop with a pit today and had them check it. He didn't seem to think much of it. Said he's seen worse. I parked it and crawled back under and it is only a slight movement. It's VERY hard to crawl under this truck. Me getting up under there is like putting a round peg in a square hole. Fat people and car haulers don't mix.
