Truck is getting hot
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hass, Mar 14, 2010.
  1. hass
    hass Bobtail Member
    bethalto Il
    Driver says truck is getting hot but not blowing hot air and is starting to use more water?
    Said it gets up to 210 and no hot air then drop to 180 real quick and start blowing hot air again Im thinking its the thermostats and its boiling the water over? Any thoughts on this
  3. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
    sounds more like a circulation issue , heater air should be hot with a thermostat problem BTW what engine , truck, location ETC:biggrin_25515:
  4. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    When it is Cold check the coolant level. If it is a Cat, then I would say the water pump impeller is loose. To test it you have to put a pressure gauge in the block and see if you get coolant preasure, You should have at least 15 lbs above rad cap preasure if you take it to tempature, or if you run it up cold at say 1500 RPM and the preasure goes up and down, and it is full of coolant the pump is NO GOOD.
  5. Turbo45
    Turbo45 Bobtail Member
    39
    6
    Nov 16, 2009
    x2 on the loose water pump impeller
  6. Heavyd
    Heavyd Road Train Member
    7,828
    6,277
    Feb 4, 2009
