Truck problems
Discussion in 'Ask An Owner Operator' started by SH42, Sep 19, 2023.
  1. SH42
    SH42 Bobtail Member
    14
    6
    Feb 22, 2011
    I have a freightliner Columbia, abs is leaking checked all brake chambers by pinching off all lines one at a time still leaking. Only leaks when brakes are released. Any help would be appreciated.
  3. Big Road Skateboard
    6,963
    39,367
    May 2, 2021
    Quick release valve under 5th wheel. Pinch off the blue line between QR Valve and ABS valve.
    Release brakes and see what happens. The QR valves often go bad, sending air down the blue line into the ABS valve, causing the ABS valve to leak out the exhaust
