Truck roll over
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by magoo501, Jan 25, 2021.
  1. magoo501
    magoo501 Bobtail Member
    Jan 25, 2021
    I had a driver roll over a 2011 Peterbilt, truck was on its side for about 8 hours, The insurance company is totalling the truck. I want to buy the salvage as the truck has only 70000 miles on a complete rebuild. Many other new parts on the motor, basically everything under the hood is new. My question is, what are my concerns and what is a good checck list to see if the engine has gotten damaged. It is a Mercedes Benz engine and i would hate to throw away the 38000 i spent to rebuild it. What do i need to look for to determining if the motor is still good.
  3. bad-luck
    bad-luck Road Train Member
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    Wow! $38k for a rebuild! I can see why you want to salvage the motor. Main thing that you need to know is if the motor shut of when the truck rolled, or if the driver shut it immediately. If not the engine most likely would have been running with out oil pressure and would damage the engine
    Dave1837 Thanks this.
  4. 062
    062 Road Train Member
    6,330
    33,970
    Oct 20, 2013
    I’d hook up a laptop or scanner and see if it shut off from low oil psi. Probably pull the pan and look at the bearings regardless.
    @Goodysnap @spsauerland
    Hye Thanks this.
  5. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Wow what model Peterbilt? Never seen a Pete with a Merc engine. But I am thinking in a Class 8 truck.
    Bean Jr., magoo68, Hye and 2 others Thank this.
  6. AModelCat
    164,716
    Mercedes? Thought that was a Daimler thing?
    Bean Jr., magoo68 and bzinger Thank this.
  7. magoo501
    Jan 25, 2021
    ok i screwed up it was not a mercedes benz engine dont know why i said that it was a paccar motor my bad sorry
    Bean Jr. and Socal Xpress Thank this.
  8. Inderjit
    Inderjit Heavy Load Member
    770
    735
    Sep 17, 2017
    I used to work in a dealership that had a body shop. The insurance companies used to make us pull the oil pan and inspect the crankshaft bearings on all tip-overs. Not one
    engine had damaged bearings as long as the oil stayed in the engine. Only ever saw 2
    engines suffer bearing failure and they were mechanical engines. Both of them had the
    throttle pulled open in the crash and the oil all blew out the vent on the ground while the
    engine ran at high idle until it ran out of fuel or seized.
    shatteredsquare and Bean Jr. Thank this.
  9. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Easiest thing is talk to the driver and see if the engine shut itself off, he did it or no.....from there, if you have access to the truck (im sure its someplace accessible) see if it runs properly etc....
    Heck if it cheap...worse case is you salvage a bunch of parts.
    Its a crap shoot but like i said, if its cheap and you can use the salvageable parts.....
