Truck setup
Discussion in 'Flatbed Trucking Forum' started by willmane80, May 16, 2019.
  1. willmane80
    willmane80 Bobtail Member
    I'm looking into getting a truck to do flatbed I've read a couple other threads saying get the right set up you're talking about gears rear end but I didn't see anything specifically telling you what to look for I'm new to flatbed so I'm trying to get as much help as possible oh and it's not going to be a new truck it's going to be between 2015-17 I know to look for a mid-roof but all the talk about ratio and power I'm somewhat lost oh yeah I'm going to be running through Virginia so a little bit of mountain and also it's going to be General flatbed Freight.
    To simplify the question what trucks with a "good set-up" would anyone recommend to look into.
    Anyone can help I would really appreciate it.
  3. TripleSix
    133,461
    General freight, some OSOW? Minimum 500hp, 13 speed and 3.55 rears.
  4. willmane80
    Ok nah no oversize or overweight
  5. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    These days most used trucks fit fine. Make sure you can fit a cab rack on the back without interference with fuel tanks or trailer. I like a longer wheelbase than some of these company spec dryvan trucks.
  6. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    If your truck has exhaust stacks coming up the back of the cab, you need to leave a gap for that exhaust stack when you mount your headache rack. Now your headache rack limits the amount of front overhang if you haul any long steel beams or pipes. You may end up permanently sliding your 5th wheel all the way back. For this reason I would look for a truck with exhaust stacks on the side.
    x1Heavy Thanks this.
  7. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    Wheelbase and sleeper size will dictate that.
    Lepton1 Thanks this.
  8. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    At least a 240 wb.
    I ran a Cascadia with a 236 and it was iffy at times ( using an enclosed headache rack). Even a tall load flush with the front of the trailer could cause problems if you were turning to/from a steep incline/decline. Sure you can adapt and take a shallow angle. Any front overhang was undue stress. If it was low (close to the deck) it wasn't too bad, but as it gets higher you start to run out of room.
    244 wb to make life easy for "general" flatbed freight?
  9. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    How big was your bunk?
    snowman_w900, Lepton1 and skellr Thank this.
  10. skellr
    8,735
    12,187
    Jul 17, 2011
    Ahh yeah..
    60"
    Lepton1 and cke Thank this.
  11. Lepton1
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    To a great extent that is true. The truck I just sold, an '03 T2000 had the muffler on the back stack. That meant my headache rack had to allow for about 12" of room. That's a lot. If I were to do it again I would definitely get a truck with stacks on the side.
    The company I work for now runs all Peterbilt 389's. Side stacks. All their side boxes and headache racks are custom built in house. Since we frequently change trailers and types of trailers, that means we have to have all securement and dunnage in the truck. The amount of storage on the truck is essential.
    For an owner operator, pulling only one trailer (as I did), you can get away with less storage on the truck and have side boxes on the trailer. None of the company trailers have storage, unless you count the RGN's for ramps, wood, and "wings" for wider wheel loads.
