Truck shut down......!
Discussion in 'Volvo Forum' started by jdmach77, Jul 5, 2014.
  1. jdmach77
    jdmach77 Light Load Member
    54
    9
    Jan 19, 2012
    New Jersey
    I was driving on I-75 in Kentucky all of the sudden the truck lost power and engine stall. It doesn't want to turn on all I am getting is (Vehicle VCU needs maintenance) I tried to get a diagnostic on the engine ecm and communication fails.
    All I get is a code through the vcu it is the following.
    MID 144 PSID 200 FMI 9
    Any help would be appreciated.
  3. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,996
    19,137
    Mar 9, 2014
    In a van down by the River.
    Does it need a regen???
  4. jdmach77
    54
    9
    Jan 19, 2012
    New Jersey
    Nop is a 2005 ved12d
  5. wonderdog24
    wonderdog24 Medium Load Member
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    Check your batteries..... Sounds like you might have lost power to the ecm..... Loose ground wire.....
  6. jdmach77
    54
    9
    Jan 19, 2012
    New Jersey
    I also checked all the cables that goes from the battery and the fuse it all looks OK some rust but I cleaned up as good as I can and nothing. It won't turn on.
  7. morlandoemtp
    morlandoemtp Light Load Member
    185
    95
    Jul 5, 2014
    New York
    Try checking your coolant levels, oil, and temp gauges if you haven't already.
  8. Grumppy
    3,234
    11,403
    Dec 11, 2010
    West Monroe, La
    OK, just to be clear,
    1) its not turning over?
    2) OR its turning over but just not starting?
    3) OR/& You turn the key on & get instrument indications & warning lights etc but nothing else?
  9. jdmach77
    54
    9
    Jan 19, 2012
    New Jersey
    uploadfromtaptalk1404604279208.jpg this is the code
  10. jdmach77
    54
    9
    Jan 19, 2012
    New Jersey
    It is turning over, not starting.....
  11. wonderdog24
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    You have a broken wire that powers the ecm... or it's grounding out on the frame somewhere.... Pull the power plug on the ecm n test it with your multimeter
