Truck sneezing
Discussion in 'Ask An Owner Operator' started by Schöne, Jul 24, 2020.
  1. Schöne
    Schöne Bobtail Member
    47
    20
    Feb 23, 2019
    Hi guys, why does my truck "sneeze" every few minutes while idling? Thanks
    Lumper Humper Thanks this.
  3. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,945
    3,317
    Jun 10, 2019
    It's purging the moisture out of the lines. Also known as the "dryer." But if it does it too often it's annoying as hell for people around you and you need to get it fixed.
    TallJoe, HoneyBadger67, xsetra and 3 others Thank this.
  4. Doealex
    Doealex Medium Load Member
    597
    1,132
    Feb 21, 2018
    Your air dryer and/or it’s filter needs to be replaced.
  5. AModelCat
    166,284
    Or hole in discharge line, leak on wet tank.
    xsetra Thanks this.
  6. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    It’s obviously allergic to something you’ve parked by so I’d suggest moving to a new spot. Hahaha
  7. Cattleman84
    Cattleman84 Road Train Member
    10,057
    71,979
    Nov 1, 2017
    The Sticks, Idaho
    watch your air guages for a few mins while it does this... Does the guage slowly go down then come back up quickly until it "sneezes"... Then it slowly goes back down amd comes up again quickly and "sneezes" again? If this is what it is doing you have an air leak some where... If it is anything less than 5 mins between "sneezes" while parked and idling, then you need to find that leak, or leaks, and get it fixed. A small leak can become a major leak very rapidly... And major leaks can cause very, very bad things to happen... Things like no brakes, or auto shift tranny to not work.
    Dave_in_AZ, xsetra and motocross25 Thank this.
  8. 201
    201 Road Train Member
    12,917
    26,596
    Apr 16, 2014
    high plains colorado
    :eek: This tears it,,I'm sorry. Laughing so hard, I can't even go on,,,I can't wait for, Old Man, Rank, Buddyd, TripleSix, and all the other so called legends of our time,,you've got to be kidding.
  9. Lumper Humper
    2,084
    8,872
    Nov 23, 2018
    Pacific North Wet
    My truck had a nasty cough one time, i put Some dayquil in the fuel tanks.
  10. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    I would get it a Covid test before you infect other trucks.
  11. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    Benadryl, Tylenol Extreme cold and flu, have been known to control sneezing.
    a box or 2 of Kleenix tissue, also helps, wiping up the snots.
