Truck Spec choice
Discussion in 'Ask An Owner Operator' started by Team Rosling Trucking, Jul 8, 2021.
  1. Team Rosling Trucking
    Team Rosling Trucking Bobtail Member
    Jul 8, 2021
    About 18 months out from picking a truck. But when I’m looking around, 2 things lurk in my mind.
    1. Do you consider weight of the tractor and what kind or how much of freight you can haul?
    2. These older late 90’s tractors that don’t have def, are they exempt in CA? Or just restricted?
    I’m involved in a company right now that hauls bulk liquids out of CA, and I know I always want carriers that can haul as much as possible per trip of the product, but I also know my trucks need DEF when we go down.
    Thanks for the input.
    singlescrewshaker Thanks this.
  3. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    No ca if running old iron. Most highway spec trucks are around 1000-2000 lbs of each other. A large car is gonna be a bit heavier than a plastic set back axle
  4. Team Rosling Trucking
    Jul 8, 2021
    I was just thinking the difference between a big Volvo with a 68” sleeper and a Kenworth with a 48” sleeper.
    Also, going O/O early 2023, can you be successful with just power only? Or should I anticipate finding a trailer?
  5. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Power only you have a lot less options. If your thinking of going that way you'll be better off leasing to a good carrier than doing PO. Somewhere like Landstar with their trailer that you can pick your own loads and using their wagon. Or a smaller carrier like where my uncle works. He has his own authority but pulls their wagon for a bigger percentage than what the leased on guys get.
    It's up to you. If you don't mind doing all the paperwork/back office work your better off running your own show. But on the plus side of being with a carrier like my uncle is, is access to dedicated freight. Most of it being contract freight in this example.
    Edit: if you don't want to do the leg work booking and negotiating loads you can still make out very well being leased on. The hard part is finding the right carrier. Pretty much cross all the big ones off your list, it'll save you a lot of headaches. Besides mercer/LS if you wanna run it like your own. My uncle has been pulling a company trailer with his own auth since 2006, has no plans of leaving. My dad was leased on at the same place 1988-02. Small 25-30 truck fleet. If you don't wanna "chase everything" you'll be better off doing that. Find your niche.
    Your talking 2023, no idea how the market will be then. It's all speculation now that far out
    singlescrewshaker and Bean Jr. Thank this.
  6. Pa_Polarbear
    Pa_Polarbear Bobtail Member
    27
    26
    Jun 21, 2021
    If this is your first o/o job id look at leasing on. There's alot to learn running your own show. Landstar or mercer are good choices but keep in mind with most big carriers they have an age restriction on tractors. Only guys I know of that still run old iron there were grandfathered in. If you want to run an older truck find a small carrier like stated above and run for them for a bit before venturing out on your own.
    singlescrewshaker and Brettj3876 Thank this.
  7. 201
    201 Road Train Member
    12,791
    26,323
    Apr 16, 2014
    high plains colorado
    Kenworth might be a bit heavier, but you have resale and a better truck and dealer network.
    Bean Jr. Thanks this.
