Truck Started on its own
Discussion in 'Freightliner Forum' started by BHarbinson74, Feb 18, 2022.
  1. BHarbinson74
    BHarbinson74 Bobtail Member
    18
    17
    Oct 7, 2020
    2014 Cascadia
    1. Wipers started going on their own while driving then stopped.
    2. Few hours later the city horn started blaring on its own. Driver disconnected.
    3. While in sleeper same night truck started on its own then stopped almost instantly.
    4. Smoke came from the fuse box area on the passenger side. Driver at this point disconnected the battery terminals until this can be figured out.
    Has anyone encountered these issues on a Cascadia? It's been raining all day yesterday I don't know if that makes a difference.
    baha Thanks this.
  3. Big Road Skateboard
    7,161
    40,566
    May 2, 2021
    Sam cabin module shorted out. Only about a 30 minute job to replace, but it does need to be programmed.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    You will need to find the water leaks above and around the wires and connecting plug in, or put all fuse boxes in heavy duty zip lock bags and seal them from water leaks?
    Rideandrepair and BHarbinson74 Thank this.
  5. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Try checking and cleaning grounds and connections at batteries and fuse box and any other place for corrosion before throwing parts at it.
  6. BHarbinson74
    18
    17
    Oct 7, 2020
    "Cam cabin module shorted out. Only about a 30 minute job to replace, but it does need to be programmed."
    that was my gut instinct as well thank you
    Rideandrepair Thanks this.
  7. BHarbinson74
    18
    17
    Oct 7, 2020
    I have someone looking at it now - going through everything before we get the Sam Cab. Thanks
  8. BHarbinson74
    18
    17
    Oct 7, 2020
    Issue Resolved. Sam Cab was the problem. Had them reseal the top marker lights and also gonna take it to the body shop on Monday to have tested for more leaks. Thanks, fellas.
    bzinger and Lennythedriver Thank this.
  9. Lennythedriver
    Lennythedriver Road Train Member
    2,414
    8,235
    Feb 14, 2020
    When you got to the point the truck started on its own, that’s enough for me. I would not stay in that truck. Lol that’s like haunted or something
    JoeyJunk and BHarbinson74 Thank this.
  10. BHarbinson74
    18
    17
    Oct 7, 2020
    LOL. First thing driver said was "Man I almost died". It's always funnier after the fact.
    JoeyJunk and Speedy356 Thank this.
