truck steer weight
Discussion in 'Ask An Owner Operator' started by peterbilt365, Apr 11, 2021.
  1. peterbilt365
    peterbilt365 Bobtail Member
    12
    Mar 27, 2021
    How much is your steer axle weight empty ?
    How much is your drive axle weight empty ?
    On my 2012 peterbilt 365 three axle steer axle is 10960 and drive axle is 7980.
    My gvw is 13200 on steers and 40000 on drives.
    Im just trying to learn more about this, my fifth wheel is fixed and i wondering if i will have problems hauling dry van , any info will be appreciated
  3. 77fib77
    77fib77 Road Train Member
    11,730
    77,631
    Jul 7, 2010
    St Louis
    You have 4 axles or 3 on the tractor.
  4. kemosabi49
    10,992
    47,986
    Jan 13, 2013
    SW Arkansas
    Your rears may have a 40k rating but you still can only gross 34,000 on your drives. Your steers you can (in most states) run the max weight of the weakest component. If your tires are rated at 6600gvw then you can go that 13,200. Most steers are rated somewhere around 6175 so 12350 would be your max. If your truck has been doing heavy haul or maybe oil field then your tires etc may be beefier. Not much you can do until you get a good load on and weigh it.
    Snoopycda and slow.rider Thank this.
  5. peterbilt365
    12
    Mar 27, 2021
    i have 3 axles
    my truck did come from texas oil fields
    i was just wondering what other trucks were weigh in at
  6. peterbilt365
    12
    Mar 27, 2021
    3 axles
  7. Ridgeline
    22,752
    124,049
    What does the sticker say on the cab?
  8. slow.rider
    slow.rider Road Train Member
    2,005
    4,741
    Apr 4, 2017
    NYC
    Get yourself a pair of load range H steers. They'll look and ride like regular steers but have a capacity of around 14k, which will let you use the full 13,200 on most major roads. I keep my 5th wheel slid forward and I've never had my steers go over 12,850. The rest can be handled by sliding trailer tandem - or if not, the trailer needs reworked.
    86scotty Thanks this.
  9. SmallPackage
    5,818
    18,639
    Dec 20, 2019
    Marion Texas
    75% or more of the oilfield trucks in Texas run 11r24.5 LRH on all three axles because they spec heavy.
    slow.rider Thanks this.
  10. SmallPackage
    5,818
    18,639
    Dec 20, 2019
    Marion Texas
    A farmer friend bought an ex Weatherford 3 axle T800 that was heavy spec so he could move a dozer around. He said that thing weighs around 24,000 sitting bobtail. No way to lighten it that I can see without changing frame.
  11. peterbilt365
    12
    Mar 27, 2021
