truck will not start.
Discussion in 'Volvo Forum' started by Socal Xpress, Jan 21, 2016.
  1. Socal Xpress
    1,752
    1,781
    Dec 6, 2014
    Los Angeles, Ca
    2010 630 d13 645k
    The batterys about 1 year old. I load tested and all are good. They all sit at 13 volts. I reconnect all wires and go to start. I loose all power. I touch the battery cutoff switch and everything lights up but will not crank the engine.
    Bad switch or keep looking?
    So much fun being stuck in Palestine Ar at the Loves and mechanics on lunch
  3. upallnite
    upallnite Light Load Member
    165
    115
    May 15, 2010
    Hempstead,TX
    sound like you hit the nail on the head with the kill switch. I would take the leads off and connect together, take the switch out of the circuit. sounds like bad connections inside. I have two of those on my KW and mine did he same thing down in AL one evening just about dark. good luck!
  4. Socal Xpress
    1,752
    1,781
    Dec 6, 2014
    Los Angeles, Ca
    Update mechanic walked up ...I explained to him the probelm. So I asked him to turn the ignition while I touch the cutoff and bingo fires right up.
  5. upallnite
    165
    115
    May 15, 2010
    Hempstead,TX
    Way to go! have a good night and a safe journey!
  6. Socal Xpress
    1,752
    1,781
    Dec 6, 2014
    Los Angeles, Ca
    Thanks upallnite. Dealer had 1 in Memphis Tn. Was surprised at how much it cost.191 plus tax.
  7. CAMPDAVID24
    CAMPDAVID24 Bobtail Member
    5
    Feb 23, 2021
    I have 2014 d13..won't crank. What should we check. They saying the starter is ok.
  8. Rob100100
    Rob100100 Light Load Member
    197
    109
    Mar 5, 2016
    Check your battery cutoff switch as he did above. Check your wiring and the switch itself.
  • Draft saved Draft deleted
