Truck won’t start Sid 248 fail 02
Discussion in 'Freightliner Forum' started by Arodjasso23, Mar 31, 2020.
  1. Arodjasso23
    Arodjasso23 Bobtail Member
    13
    Apr 18, 2019
    I have a 2007 freightliner Columbia MBE4000 the truck was running fine sat over the weekend and Monday wouldn’t start turn the key and truck cranks but won’t start. The check engine light is on and it has codes sid 248 fail 02. Any idea how to approach this? Thanks in advanced
    Danielromero Thanks this.
  3. JohnnyC
    JohnnyC Light Load Member
    173
    65
    Feb 17, 2009
    virginia beach, virginia
    First thing I learned about 12v. Clean all the cables to the battery. Next check grounds. Next check ECM connection.
  4. Danielromero
    Danielromero Bobtail Member
    [QUOTE = "Arodjasso23, post: 10181648, member: 250796"] Tengo un Freightliner 2007 Columbia MBE4000, el camión estaba funcionando bien el fin de semana y el lunes no comenzaría a girar la llave y las manivelas del camión, pero no arrancará. La luz de verificación del motor está encendida y tiene códigos sid 248 fail 02. ¿Alguna idea de cómo abordar esto? Gracias de antemano [/ CITA]
  5. Majagua88
    Majagua88 Bobtail Member
    Any solution?? Im hqving same problem
  6. Diesel 2023
    Diesel 2023 Bobtail Member
    Has any one ever fixed this problem
