Truck Won't Start! HELP
Discussion in 'Volvo Forum' started by 325TahoeSS, Feb 9, 2014.
  1. 325TahoeSS
    325TahoeSS Light Load Member
    150
    71
    Feb 11, 2012
    Roma, Tx
    I turned off my truck last night & this morning I cranked her up & she started then she started to shake like she was out of fuel or something then she shut off! She cranks but won't start! Need help!
  3. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Need a bit more info, is it cold or are you freezing up? Outa fuel?
  4. 325TahoeSS
    150
    71
    Feb 11, 2012
    Roma, Tx
    Got 1/2 tank of fuel it's 41 degrees outside
  5. 325TahoeSS
    150
    71
    Feb 11, 2012
    Roma, Tx
  6. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    and did you look at the fuel filter to see if you have fuel
  7. 325TahoeSS
    150
    71
    Feb 11, 2012
    Roma, Tx
  8. yuban
    yuban Medium Load Member
    342
    347
    Jun 3, 2009
    Between 2 Doors
    Contaminated fuel. Hope no one spiked your tanks...
  9. 325TahoeSS
    150
    71
    Feb 11, 2012
    Roma, Tx
    I turned it off running! It did this to me yesterday, started ruff then hit the gas & it quit shaking/missing & I've fueled since then already
  10. Buckeyes614
    Buckeyes614 Light Load Member
    156
    156
    Jan 22, 2014
    Somewhere in ur fuel line is clogged. Seen this happen to a driver before, replace the fuel filter first.
  11. tsavory
    tsavory Road Train Member
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    drain the fuel/water separator prime the heck out of it try again.
    I agree its clogged or the is a crack in a line thats letting air in so it can't build the pressure feed the injectors, or a bad ground on the injectors
