Truck won't start
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TylerDavid, Nov 24, 2017.
  1. TylerDavid
    TylerDavid Bobtail Member
    25
    9
    Jul 8, 2015
    Hey any and all help is much appreciated.
    Yesterday I was unhooking from trailer when another driver started a conversation. Lasted 10 minutes then I made a rookie mistake and had set landing gear and pulled lock but left airlines/pigtail and, u guessed it, ripped it off. The pigtail at the trailer end ripped apart and all the wires were exposed to one another and this caused my truck to die instantly. The dash gauges froze, no power to exterior lights/sleeper/dash. Only a few things work (door light, 4 ways, fridge, cig lighters, and side box lights when open). Roadsquad came out replaced one battery and charged the rest so Its not that. No circuit breakers were triggered except trailer and ecu. When I turn my key there's no crank no click, and no power to radio or dash. I've checked all the fuses and the fuses are fine. There might be some under the dash that I haven't come across yet but idk what else this could be. I have a mechanic helping me he's going to check for replacement ignition relays to see if that's it. If you have any ideas I'm all ears. Also there's no starter circuit in the fuse panel.. but that shouldn't have anything to do with why the lights aren't working just found it weird it wasn't there.
    Sorry for the novel
    -Tyler
  3. Heavyd
    Heavyd Road Train Member
    7,830
    6,281
    Feb 4, 2009
    What kind of truck/engine?
  4. TylerDavid
    25
    9
    Jul 8, 2015
    2017 international lonestar with an isx15
  5. Ridgeline
    22,776
    124,545
    There should be fusible links to the ecm that can blow open with a surge, these are there to protect the ecm.
    And I assume that when you say won't start, you mean won't turn over.
    aussiejosh Thanks this.
  6. aussiejosh
    aussiejosh Road Train Member
    4,798
    5,650
    Aug 28, 2009
    Airlie Beach QLd
    Yeah check the fuses dude and call out an auto Electrician he'll have it fixed in no time
  7. TylerDavid
    25
    9
    Jul 8, 2015
    If they are right 5 and 30 amp fuses that are close to the battery bank those are good
  8. TylerDavid
    25
    9
    Jul 8, 2015
    I have he came earlier, left to get his computer, I'm just waiting for him to get back. Thanks for the help man, I appreciate it
  9. Heavyd
    7,830
    6,281
    Feb 4, 2009
    Check the mega fuses at the fire wall under the hood.
  10. TylerDavid
    25
    9
    Jul 8, 2015
    U were right, it was the mega fuse. Thanks for the info.
    Unfortunately I didn't know what to look for which costed me $1300...
    When I read "mega fuses" I was unclear on what the fuses should look like, now I know. Thanks for the info
    Heavyd and Oxbow Thank this.
  11. AtticusRoad
    AtticusRoad Medium Load Member
    301
    688
    Oct 30, 2016
    Indiana
    Dog run away?
    Did she run off?
