Trucking gears question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hazzmatt89, Oct 3, 2023.
  1. hazzmatt89
    hazzmatt89 Light Load Member
    64
    56
    Oct 3, 2023
    I’m about to pick up a 94 international 9400 this week. It has a 3406e 465 hp with a 10 speed Eaton and 373 spicer rears… truck has 700k miles on it and the bottom was done awhile back not sure exactly what. But the price is right for my budget which isn’t much at the moment.
    my question is this a good set up I have been trying to find some info on them and can’t really find too much. I had a freightliner century before with a Detroit, so this will be my first truck with a cat and these gears on it. Any input would be appreciated. I love this forum and just signed up today. I have been doing some research on the engine. i plan to haul logs locally here in South Carolina hopefully
  3. Big Road Skateboard
    7,159
    40,552
    May 2, 2021
    It'll work just fine for normal truckin. Not sure about the terrain where you'll be workin
    Deezl Smoke Thanks this.
  4. hazzmatt89
    64
    56
    Oct 3, 2023
    not planning on going into much mountains some hills in the upstate Probally running around columbia South Carolina and the back roads around the area staying locally around Greenville, Columbia, and some areas around there hopefully
  5. skallagrime
    skallagrime Road Train Member
    3,855
    9,928
    Apr 10, 2012
    Indiana
    Keep to 65mph and she'll treat you right, assuming lp 22.5 , will feel a bit gutless with any weight on any hills with bigger tires.
    13 speed if you do hills
    Do NOT go over 65 if you like good mpg
    beastr123 Thanks this.
  6. hazzmatt89
    64
    56
    Oct 3, 2023
    Thank you, guy I’m getting it from runs Florida only flatbed with steel. Says it’s got good power I’m flying down Saturday to pick it up and run it back to South Carolina. I’m not looking to drive fast but he says it will go if you need it to
  7. Deezl Smoke
    Deezl Smoke Medium Load Member
    540
    356
    Feb 12, 2011
    Hillsboro Oregon
    Then you bought yourself a gem. The detroit in the century did'nt really care all too much for short shifting, but the E cat will appreciate it.
    In 94' year model, is that a super 10? The cat will get by just fine if it is, but keep the air clean as you will be using the splitter a lot.
    3.73s are plenty high numerically, so hopefully it has 275/ or 11Rs on it. But for locals and back roads etc., :Trailer::thumbup:
  8. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    Will be a turd at that hp even with the 373 gears.
  9. hazzmatt89
    64
    56
    Oct 3, 2023
    Well for the price I’m getting it for I’ll make money with it. So I really am not looking for a race truck. But thanks for your input even though you really didn’t say anything at the same time as saying something.
