Trucks
Discussion in 'Ask An Owner Operator' started by celery425, Apr 17, 2014.
  1. celery425
    celery425 Bobtail Member
    27
    Nov 12, 2013
    I was wondering what trucks you guys would recommend and why.
  3. GearWarrant
    GearWarrant Medium Load Member
    403
    175
    Mar 20, 2014
    North Vernon, IN
    What do you want to pull? Flatbed, van, reefer, heavy. What kind of truck depends on the application.
    celery425 Thanks this.
  4. FLATBED
    FLATBED Road Train Member
    Just to add to the ?'s above Get 1 that does the job and you can afford and do not worry about the EWWS and AHHS when you pull into the truck stop
    281ric and celery425 Thank this.
  5. 281ric
    281ric Road Train Member
    1,248
    809
    Oct 20, 2011
    TX
    some of the best advise I have heard in regards towards truck purchase.
    celery425, mp4694330 and FLATBED Thank this.
  6. wore out
    wore out Numbered Classic
    17,521
    218,860
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    What he said. Depending on the work at hand, and the way you drive determines the best truck. Then of course every body has their opinion.
  7. celery425
    27
    Nov 12, 2013
    dry van and reefer.
  8. celery425
    27
    Nov 12, 2013
    No price range just wondering.
  9. mp4694330
    mp4694330 Road Train Member
    1,530
    1,461
    Aug 30, 2010
    Chicagoland
    Aerodynamic glider if new and no CALI.
  10. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Personally I would look for a pre EGR truck. Far more reliable then trucks made after that. Then specs , what works great for one app may stink in others. Had a fleet from 86 that was perfect for their job (made just for the contract) , they got over 10 MPG . But would not work correctly on what I do now. So it's important to know what the truck will be doing!
    If a newer truck is "needed" buy one that has DEF (diesel exhaust fluid) on it. Cured a lot of the issues from EGR and EGR + DPF trucks (2004 thru 2010) . DEF , you need to keep its tank as full as you can. As DEF dries it forms a crystal . These crystals stop up the plumbing . If the tank gets low , the fluid may splash up on the upper part of the tank once or twice a day. Then dry forming these crystals . Then wash off the inside of the tank next fill up , causing issues.
    Next is glider kits. You get a remaned engine without the emissions headaches and a new cab and chassis . Almost best of both worlds!
    All that said the company I work for , has many different specked trucks. That run on different fuel types even. Depending on job required and location. Hope this helps some ?
    trees Thanks this.
  11. rooster69
    rooster69 Bobtail Member
