TRW steering gear leak
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Oscar the KW, Dec 9, 2013.
  1. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    I have a TRW box that was leaking out of the input shaft seal, bought a new seal and didn't have a plug to plug the return line and blow the seal out. So I removed the 4 bolts that hold that top cap down and I could not get the top off, it came loose, but I didn't want to use to much force and break something, so I put the bolts back in and got a plug and blew the seal out. After putting the new seal in it, it is now leaking around one side of the cap that I took loose. Is there an O-ring or a gasket under that top piece, and how do I get that top piece off?
