Trying to read fault codes, says "unexpected answer from control unit"
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by elliott, Feb 22, 2023.
  1. elliott
    elliott Light Load Member
    103
    30
    Sep 3, 2007
    I'm using Jaltest to read fault codes on a 2019 Pete with an MX13. When I connect to the HVAC/Climate control system in Jaltest and click on read fault codes, I get "unexpected answer from control unit."
    What does that mean? Pic attached for verification.
    I'm trying to solve an intermittent cabin heating issue; sometimes the heat works, sometimes it doesn't. Now I'm wondering if the inability for Jaltest to communicate with the control unit might be related.
  3. Goodysnap
    Goodysnap Road Train Member
    3,774
    9,202
    Jul 12, 2017
    Might need ESA. I have customers that use Jaltest for engine faults. Not sure if it will talk to HVAC. Have you tried just reading Cab controller/ CECU codes? I seem to remember seeing them on the reports.
    elliott Thanks this.
  4. elliott
    103
    30
    Sep 3, 2007
    Yes, but nothing in the CECU codes related to climate control; lots of turn signal faults come up, though, so that was surprising. Anyways, I think you are right that Jaltest won't talk to the HVAC system, as that explains the weird message.
    I'll look into ESA. Problem is that we also have Western Stars with Cat, Detroit, and Cummins engines, so ideally we have something that can communicate with everything. Thanks for the help.
    Goodysnap Thanks this.
