Tubro Down Pipe Sizing
Discussion in 'Trucks [ Eighteen Wheelers ]' started by billandlori, Aug 26, 2011.
  1. billandlori
    billandlori Medium Load Member
    357
    107
    Sep 5, 2010
    Stratford, Ontario, Canada
    I was just wondering if it is better to run a pipe the same size as the turbo housing outlet or if a larger stepped pipe, or no pipe at all would allow better breathing?
    I have read about guys putting a wrap on the pipe for a ways back.
    Thanks for the thoughts!!
    Bill
  3. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    Diesels like to breathe. Larger the better. To constrict the pipe by going smaller will rob you of necessary horsepower.
    Other thing that helps is more intake, less restriction for air comming in the better.
  4. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,180
    Apr 20, 2011
    Dahlonega, GA
    You can "play" with the size of the pipe, too big and it will hurt torque numbers unless your engine is really modified.
  5. dave26027
    dave26027 Road Train Member
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    You've got to maximize the effects of "exhaust scavenging" with the right diameter and length pipe. If you're a gearhead you can really overstimulate your brain on this subject, EVERYBODY wants the maximum effect. You might try Googling it, it's TMI to get into here.
    The wrong size pipe (diameter or length), a split for dual pipes in the wrong place (too close or too far from the turbo) and a bunch of other details can change the torque curve or mileage in your motor. Sometimes not for the best.
    Interesting subject..
  6. milskired
    milskired Road Train Member
    3,829
    1,401
    Jul 20, 2007
    Plainfield, IL
    I would have to say 5 inch is a pretty good size. Seems most come stock with 5 inch. Keep in mind that getting a free flowing muffler of some sort will help more with lowering your EGTs and getting a better response out of your turbo/s. I would say go with a 5 inch DP and go with a good set up flow through mufflers.
  7. billandlori
    357
    107
    Sep 5, 2010
    Thanks! I was thinking about stepping up to larger size as it flows away from the tubro. Or splitting into two fairly close.
    Bill
  8. billandlori
    357
    107
    Sep 5, 2010
    This is the place for tech, right!!! Just doing some bench racing!!
    I wonder if there is a formula for pipe diameter and length..... There is lots of formula's for gas engines etc.....
    Bill
  9. billandlori
    357
    107
    Sep 5, 2010
    Yep! I'm sourcing some donaldson's. Should help some.
    Bill
  10. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    Sorry, not trying to hijack but I have be wondering something. I have the wrap to do mine from the beginning of the flex pipe off the turbo all the way back under the cab to the bottom of dual 5" stacks. Haven't done it yet though. With dual straights do I need to worry that the wrap will negatively affect my EGT's? I don't have a pyro to tell me. Just trying to lower my under hood/cab temp and reduce the fire risk from the chaff that builds up on my tanks and surrounds the exhaust.
  11. lovesthedrive
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    A really great insulator (not sure if you can get it) is fiberfrax. Used it on miniature boilers in the Live Steam hobby. I highly recomend it if your going to insulate your pipes.
