Tuning an ecm
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Unidewking, Nov 5, 2019.
  1. Unidewking
    Unidewking Light Load Member
    84
    66
    May 3, 2018
    So my boss has a c13 in an internstional 9200i and it has been flashing 9-3 iva code for a while and we are just now gettin it to a shop. Looks like he is going to have the shop "tune the ecm" so as to not use the IVAs. So he was just wondering what all happens and what does a person do to the ecm and what would make it cost 1500 just to flash the computer. Thanks for any explanation
  3. benjamin260_6
    benjamin260_6 Medium Load Member
    433
    484
    Aug 8, 2012
    Ontario, Canada
    It costs $1500 because that shop can do it and you can't.
    Unidewking, AModelCat and spsauerland Thank this.
  4. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    $1500? Does that come with an oil change, overhead and a 3 axle alignment?
    It doesn't cost $1500. He's being hosed! Unless the program he's getting is something no other shop has. I know Diesel Doctor was working on a program to remove the IVAs from the equation.
    Guf and Unidewking Thank this.
  5. Unidewking
    84
    66
    May 3, 2018
    Oh man i was afraid this is what i would hear. Yeah the shop said they would unplug the iva pigtails and think i heard something about back em out and flash the computer to not use or something. Well too late i guess. Live and learn. Thanks
  6. AModelCat
    164,854
    I'd do a little research on deleting the IVA's if I were you. I seem to recall a lot of the guys on here with lots of Cat on-road engine knowledge saying that deleting the IVA's without going to a lower compression ratio will blow up stuff. The IVA's do something to limit pressures. Definitely read into it cause blowing a headgasket isn't cheap.
    pushbroom, Unidewking and RustyBolt Thank this.
  7. Unidewking
    84
    66
    May 3, 2018
    Ok so i have done some reading into ivas and what they do in the past. From what i understand they are like a jake brake on the intake valve and hold them open on the start of the compression cycle to relieve some pressures there by reducing emissions. I thought that meant it was made to handle the amount of cylinder pressure without the ivas but maybe i should do more research. Thanks
  8. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    IVAs are a jake brake for the inlet valve.
    Anyone that claims its for emissions is ill informed. They're to reduce cylinder pressure during operation. its needed because of the ridiculous compression ratio used from factory to generate the complete burn needed to meet emissions.
    without them the cylinder pressure is phenomenal. excessive cylinder pressure will make the liner flex more and chew into the deck faster. it will also generate additional heat. The most common failures seen are recessed liners causing head gasket failure and cracked cylinder heads.
    I would strongly recommend reducing compression back to the pre ACERT 16:1 if deleting IVAs. leaving it at 18:1 will still work, but the service life of the engine will drastically reduce.
    As for file cost. That is for 1 of 2 reasons. They have purchased the file to flash from someone and are simply marking it up when on selling to you, or they have spent countless hours of time developing the file with expensive software and hardware. either way they are recovering the cost of purchasing a file or capital invested into file development as the on sell to you.
    Yes, the flash is fast, but making the file wasn't.
  9. Unidewking
    84
    66
    May 3, 2018
    Right now this truck has low 700k miles and this truck is for a farm so we dont drive too many miles. I did notice that when the light turned on she alway ran more towards 190 then 180 on coolant temp. Ok so im gonna compile some questions the place when we go pick the truck up. So how does one reduce compression ratio? My limited knowledge and experience makes me think it wouldnt be an easy job
  10. AModelCat
    164,854
    You'd have to change pistons most likely.
    Unidewking Thanks this.
  11. Unidewking
    84
    66
    May 3, 2018
    Yeah that dont sound good. Ill talk to the shop and see what all they do. Thanks
