Tuning Center load Antenna
Discussion in 'CB Radio Forum' started by dealer374, Jun 25, 2017.
  1. dealer374
    dealer374 Bobtail Member
    4
    Jun 25, 2017
    I just installed a Cobra HGA7000 with a heavy duty mount and heavy duty spring. I bought a good quality cable and a have a Cobra 29LTD radio. I have a range of less than 1 mile and I usually have to crank the RF gain pretty high, but when I do they come in clear.
    -On ch. 40 my SWR started at 3 maybe a dash more, it was high > On ch. 1 my SWR started at 2
    -I cut about 1" off the top whip (has 10" mast on bottom)
    -On ch. 40 my SWR went to right about maybe a dash less > On ch. my SWR went to about 1.75
    So it went down a little as it should. I've read conflicting things with no real feedback from OP's on what they did regarding adding a spring.
    Sooooo my question is do I really need to cut the approx. length of the spring off the antenna? The coil is kinda sitting just below/almost at the cab guard so would cutting the mast to drop it between the roof line and cab guard help? Or should I just keep cutting the whip until it stops getting better? Help, what do y'all recommend?
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    I just googled it and it looks like a copy of a Wilson 2000. I would take the spring out and see where the SWR goes. I wouldn't think you'd need a spring.
    Or better yet, take it to a CB shop that has an antenna analyzer and have them tune it.
    rabbiporkchop and bored silly Thank this.
  4. Neverready
    Neverready Medium Load Member
    406
    330
    Jul 24, 2014
    Pocomoke City, Md.
    Spring length will affect SWR but not always in direct proportion. If your swr is moving in the right direction remove a bit less at a time so you don't take off to much. The antenna moving back and forth with the spring may affect your swr when you are riding.
  5. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    Lengthening or shortening the shaft of the antenna should have minimal effect on the tune of the antenna. Here is a prime example. After adding a 4ft shaft to the bottom of this antenna I only had to subtract an inch of stinger. If adding a 3 inch Spring to the bottom of your antenna makes a drastic difference in SWR, then you got other issues that need to be looked at like your mounting location on the vehicle itself, or possibly ground problems.
    I'd be curious to see a picture of this "Center load" antenna since very few people actually make such a thing.
  6. Broke Down 69
    Broke Down 69 Road Train Member
    2,733
    9,772
    Jul 3, 2016
    Concord NC
    I've been seeing a few around lately. Mostly on 4 wheelers though. Talked to a guy in a Dodge truck last week for a good while and since i wasnt in any hurry we started opening distance between us. He was clear as a bell at 12 miles when he exited and i held him for another 5 minutes or so after.
  7. wolverine11
    wolverine11 Road Train Member
    1,628
    1,234
    Apr 1, 2015
    No Micky D's drive thru breakfast with that truck, Im guessing it works pretty good.
    rabbiporkchop Thanks this.
  8. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    Personally I think it's kind of ridiculous for the roof of that truck but it was actually made for a Cascadia or T600
    wolverine11 Thanks this.
  9. wolverine11
    1,628
    1,234
    Apr 1, 2015
    Sure dont have much margin of error for hitting things, at least with a Wilson mag mount if something is hit the whip wont break, it may get a slight bend ( happened to me when I hit a low tree limb) but it wont damage coil.
  10. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    I wouldn't worry about margins of error on a tractor-trailer with a heavy duty mounting bracket on heavy duty mirror arms with an antenna with a flexible shaft, but I would definitely worry about it on a $65,000 pickup truck with a tall top-heavy antenna mounted on thin sheet metal on the roof.
  11. Ridgeline
    22,776
    124,542
    What are those 5 inch stacks for a cummins?
    Isn't that a joke?
