Turbo blow off?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ratherbtruckin, Dec 25, 2010.
  1. ratherbtruckin
    ratherbtruckin Light Load Member
    116
    39
    Nov 2, 2009
    Colorado
    Cruising down the interstate, doing 65....well, ANY speed really.....
    Turbo spools up to 50psi, then blows off to 0, then up and down again, and again. Truck chugs hard when it does this, and it probably isn't good for the fuel economy or the engine itself. Any ideas what might cause this? Its not constant, its random, and its annoying as heck. I've heard things like "clean the battery terminals" and "replace the fuel filter" neither of which helped. (new batteries and fuel filter anyway)
    Truck specs:
    Freightliner classic xl
    Detroit Diesel 60
    13spd tranny.
    AC if that matters. Double sleeper, double stack etc.
    We've checked and rechecked all the intake/exhaust flanges/boots. Everything seems airtight. Put on new air filters, new batteries, and a new fuel filter. I think the turbo is dying, but I don't know turbos or diesel engines for that matter. Ideas? Suggestions? :biggrin_2556:
  3. Donk
    Donk Have a Cup Of Concrete
    1,643
    9,232
    Apr 27, 2008
    50 psi? something is wrong there.. rather than solicit help from people whom will guess at the issue ( some rather accuratley going by past performance on here ), Take the truck to a workshop and have it ran up on the dyno.
    That will show a tech what is happening and allow them repeatability in their troubleshooting.
  4. king Q
    king Q Road Train Member
    2,880
    3,038
    Jul 26, 2010
    Johannesburg sa
    When the boost drops do you get a plume of black smoke out of the exhaust?
    I agree a dyno will be best.
  5. Eagle_Eye
    Eagle_Eye Medium Load Member
    389
    220
    Sep 26, 2010
    ClarksvilleTennesse
    Yea Dyno best idea! Bu1:biggrin_25510:t if doing this was Vpack on my 2007 Columbia then 2 weeks later Turbo blew
  6. cmc
    cmc Bobtail Member
    11
    Dec 23, 2010
    So what CAC and what CAC boots are you running on that truck?
  7. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Pull the air intake off the front of the turbo, grab the shaft and push in and pull out. If there is movement, thats you problem!
  8. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    had that on same engine---its a variable vane turbo--and a controller went-was going ok--then no turbo---so started limping back into london--turbo spooled up a couple times more then died right away---replaced controller at detroit--everything fine
    but again--best idea is to take it to a detroit shop
  9. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,488
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    This is exactly what I was thinking, wasn't sure though without knowing the year.
    orion3814 Thanks this.
  10. canuck in da truck
    4,352
    2,601
    Aug 6, 2010
    western pa
    was on a 06 detroit---and i cant remember what controller the guy changed--he said it was fairly common--it cleared up the no psi problem--but it would still once in awhile-puff and cough when pulling a hill
  11. Smalltruck
    Smalltruck Light Load Member
    141
    68
    Jul 3, 2010
    Elko, MN
    Well it could be a wastegate controller. Or a Delta P sensor (but not likely). Or a boost sensor but again not likely. Diagnosing this problem on the web is kind of hard without having the truck on a computer
