Turbo charge killed our engine
Discussion in 'Experienced Truckers' Advice' started by erinjoe, Feb 24, 2018.
  1. erinjoe
    erinjoe Bobtail Member
    7
    Feb 24, 2018
    One roadside mechanic screwed up our Freightliner ( Detroit) truck trying to turbocharge. The engine ran in sixth gear for a few minutes and then shut off. The Freightliner say the guy didn't clean the CAC charger and had damaged the engine. The company sent us an estimate for 50000 bugs. We need to prove it's guy's fault, he didn't clean before fixing turbo, then his insurance would pay us. Our only source of income is dead. Give us your best suggestion/advice, whatever, but help us out of it.
  3. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    50000 bugs converts to ??us$$
    Lepton1, Grubby, Socal Xpress and 3 others Thank this.
  4. bzinger
    bzinger Road Train Member
    16,657
    66,203
    Dec 10, 2014
    omaha , ne
  5. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    @erinjoe you sound like your not smart enough to own your own truck. No way can a roadside service clean your CAC it needs to be taken off and pressure washed. Yet even if it was not your engine should not be ruined. How does a roadside mechanic try to turbocharge?? And how does a truck run in 6th gear without starting off in first? 50,000 bugs sound like they are in your head? Your post makes no sense from the very start. I'm going to go sip some of my unicorn punch, but I will check back later.
    Lepton1, Woodys, Grubby and 7 others Thank this.
  6. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Did the roadside have liability insurance?
    If so simply file a claim and if denied then worry about fighting it.
    If not, then the phrase "Trying to squeeze blood from a turnip." comes to mind.
    Lepton1, Streetroddreams and erinjoe Thank this.
  7. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Any shop that does not sell you a new cac air cooler after a turbo blow/up is a shade tree type shop, so many small pieces of steel allready went threw your eng that they will say it was allready damaged but use your insur. to get it fix at a Det. shop where you will have a warr, to get it back on road!
    Grubby, blairandgretchen and erinjoe Thank this.
  8. Volvo8873
    Volvo8873 Light Load Member
    240
    145
    Apr 27, 2016
    Western Wisconsin
    I think we have another case of a troll coming out. Seems to be the norm lately...
  9. shogun
    shogun Road Train Member
    6,075
    72,164
    Jan 23, 2009
    Doing a regen
    Have you talked to the mechanic that did the repair yet? Do you have an itemized bill? Sounds like the seals leaked oil into the CAC and the engine ran off using the motor oil in the CAC til it blew. In the future, have something solid handy to choke off the air at the intake so it will kill the motor before it blows.
    As far as the $50k bill, tell them to pound sand. You can buy a junkyard motor installed with a warranty for less than half that if we are talking about a Detroit. Proving who is at fault will be difficult, especially in a case of a small independent mechanic.
    Lepton1 Thanks this.
  10. AModelCat
    164,925
    There's way too much missing info here.
    Did the original turbo blow up and fill the intake system with oil, which the mechanic failed to clean out when he replaced the turbo?
    Was this a new/reman turbo that failed and you're looking to hang the mechanic that installed it?
    There is so much info missing that no one here can advise you of anything without a better story.
    Lepton1, Grubby, Dan.S and 1 other person Thank this.
  11. erinjoe
    7
    Feb 24, 2018
