Turbo failure & Weak Engine Break
Discussion in 'Kenworth Forum' started by Bmolina, Dec 13, 2023.
  1. Bmolina
    Bmolina Bobtail Member
    KW T660 2012 A few years ago my turbo and actuator failed but I quickly repaired it. I thought it would solve the problem but soon after turbo/actuator failed again and engine brake went weak. I went through many mechanics, replaced parts about 4 times that year and all mechanics told me the same thing, to keep replacing turbo/actuator. Every time I would replace parts my truck went back to running back to normal for about 6 months and then again turbo/engine brake failure. I especially noticed the turbo failure after not running my truck for a week; as soon as I would turn it back on from taking a vacation I had turbo failure. At this point I’ve exhausted all my options, I’ve spent so much money and it’s not worth repairing anymore but I’m wondering if this has happened to anyone else? My truck has a delete and I’m thinking it might be a computer problem but no certified kenworth mechanic will work on it because it’s been deleted.
  3. Magoo1968
    Magoo1968 Road Train Member
    2,061
    5,492
    Mar 18, 2021
    St Malo mb
    Deletes eliminate high setting of jakes often.. someone had a thread recently on isx turbo acting up mostly due to carbon . He cleaned his and it works again.
    Bmolina Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Break - as in the engine went on a break and had a vacation.
    Brake - as in the engine helps you to slow down, like putting on the brakes to stop or slow down.
    Bmolina, QUALITYTRUCK and JB7 Thank this.
  5. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    Nobody can outrun or hide from the grammar police
    LameMule Thanks this.
  6. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    This sounds like a poor delete program, have seen many that the turbo fails in a short time and weak jakes.
    Get the right program flashed in the ecm will solve this issue.
    Magoo1968 Thanks this.
