Turbo for 855 Cummins
Discussion in 'Ask An Owner Operator' started by Tbag3, Jan 15, 2026.
  1. Tbag3
    Tbag3 Light Load Member
    90
    30
    Jul 5, 2025
    IMG_8612.png IMG_8613.png IMG_8615.png IMG_8616.png IMG_8614.png My turbo went out and started passing oil out exhaust side, I started looking around and found 2 turbos in good condition without shaft play for 75$ each. That’s very cheap so I bought both, but they are a little different from each other. Which would be better for a 1971 350 small cam. VT or AR and will both work. The intake side looks different
  3. Tbag3
    90
    30
    Jul 5, 2025
    Top 2 are the AR-12606 bottom 3 VT-50 I believe
  4. Tbag3
    90
    30
    Jul 5, 2025
  5. Tbag3
    90
    30
    Jul 5, 2025
    The AR turbo compressor housing looks short not much room for the boot, am I missing a piece it has screw holes in it
  6. Diesel Dave
    9,684
    32,928
    Jan 20, 2010
    Hesperia, Ca.
    Did you call Cummins and give them those numbers to see if it will work for your application ? And I just have to ask, why didn’t you just purchase rebuilt one like most of us do, yes I’m aware there more money but your doing it correctly and saving yourself other headaches down the road.
    AModelCat and Tbag3 Thank this.
  7. Tbag3
    90
    30
    Jul 5, 2025
    Just wanted to get everything else lined out and make sure everything is up to par before buying a new turbo. After I know the truck will be dependable I plan on getting a new ht3b. But so far so good
  8. Tbag3
    90
    30
    Jul 5, 2025
    I’ve tried Cummins but besides build date they are useless he said it is to old and could not find the cpl
  9. Ridgeline
    22,727
    123,472
    Why don't you get the CHRA cartridge for the turbo? They should be less than $500.
  10. Tbag3
    90
    30
    Jul 5, 2025
    My original turbo had a rust hole on it and was leaking exhaust and also started passing oil
  11. TripleSix
    133,392
    A rust hole THROUGH the turbo housing????
    The CHRA cartridge is the centerpiece with the two sides of the impeller, seals, bearings…etc. Usually, when a turbo wears, the seals start to leak (the oil you see blowing on the impeller, and the impeller blades collide with the turbo housing as it spins and grenades in spectacular fashion.
    Diesel Dave Thanks this.
