Turbo or air cooler
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ladytrukr, Aug 24, 2017.
  1. Ladytrukr
    Ladytrukr Bobtail Member
    47
    15
    Aug 12, 2017
    drivib my KW W900L today and I just heard a loud pop, and now I have black smoke coming from my truck... I also can't drive faster than 30 mph.... what did or am I doing wrong?
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    What year is your truck
    Black smoke is unburned fuel usually
    This would get more appropriate attention in the garage section.
    Ladytrukr Thanks this.
  4. TylerD
    TylerD Bobtail Member
    12
    17
    May 21, 2017
    Carolina
    Pull over first safe spot. Pop your hood take a look.
  5. Jace379
    Jace379 Light Load Member
    146
    97
    Mar 6, 2017
    Air to air boot or intake line that goes to the compressor
  6. Ladytrukr
    47
    15
    Aug 12, 2017
  7. AModelCat
    164,902
    Popped intake pipe would be my first guess. Pretty easy to spot. Either that or the hood rubbed a hole in a rubber intake boot.
    fargonaz and Ladytrukr Thank this.
  8. Jace379
    146
    97
    Mar 6, 2017
    Or your turbo flew apart internally
  9. Jace379
    146
    97
    Mar 6, 2017
    More then likely a boot popped though or the clamp broke or wasn't tight enough and the pipe blew off
  10. Ladytrukr
    47
    15
    Aug 12, 2017
    No hole in the intake boot, Going to check the intake pipe
  11. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Would this cause high egt also? With an electronic engine dumping more fuel in but not seeing the return in boost pressure in order to try to maintain rated power?
