Turbo trouble
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by cat 03, Sep 9, 2023.
  1. cat 03
    cat 03 Bobtail Member
    24
    8
    Mar 22, 2013
    I have just put a new 3406e cat long block in a 1997 379 pete I replaced everything on the engine with new parts including the turbo. I just cranked it for the first time it started fine oil pressure came right up but when I walked around to the turbo I had black oil running into the exhaust out of turbo. I took everything apart and have clean oil going into and out of turbo into the return line and no oil going into charge air cooler. Does anyone have any ideas.
  3. xsetra
    xsetra Road Train Member
    5,196
    7,147
    Aug 21, 2011
    Could this "Oil" be fuel with soot washed from the exhaust?
    AModelCat Thanks this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Very common with new CAT parts.
    Oil by the rings because they aren’t seated yet.
    Put a load on in and do some good pulls. It will clear up after the first day.
  5. cat 03
    24
    8
    Mar 22, 2013
    I went out and cranked it again with exhaust elbow off the turbo the oil is still building up and running out. Do I just need to run It like you said and the oil will clear itself. It looks like it would coat everything with oil. Thanks for your information
    Goodysnap Thanks this.
  6. Goodysnap
    3,771
    9,195
    Jul 12, 2017
    Yup. I in-framed a 6NZ some time ago. Dripping out of the flex pipe at hot idle.
    Make sure everything else is buttoned up and go pull some hills. When the boost builds it will not leak and will seat the rings.
    You can pay someone to break it in on the dyno too.
    Oxbow, Stay Puft, cat 03 and 1 other person Thank this.
  7. cat 03
    24
    8
    Mar 22, 2013
    Thank you I might be able to get some sleep now.
    Oxbow and Goodysnap Thank this.
  8. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    They take a little work to get broke in right, load it up nice and heavy and pull some hills as soon as you can. Drive it like normal, don't baby it.
    Oxbow Thanks this.
  9. cat 03
    24
    8
    Mar 22, 2013
    Thanks for the information
