Turbo upgrade?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by AModelCat, Oct 20, 2019.
  1. AModelCat
    164,656
    Building a 3406 PCTA (92U prefix). Factory rated 375 hp. Now the OEM turbo looks ok. No turbine/compressor damage, no excessive play or housing wear. Just curious if it'd be worth putting an aftermarket turbo on it. Not really looking to make huge power. Maybe bump it up to 400-425 max but I want it to burn clean, so quick spooling would be nice. Would the factory turbo support 425 hp?
    Wheeljack Thanks this.
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I can't say much about the A models, but an E model turbo, factory or a borg replacement will clean a b model right up enough to pass stringent snap tests.
    Shawn2130, AModelCat and swaan Thank this.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Shouldn't matter . Same displacement 14.6L engine .
    I would agree. A wastegated turbo off a E model would be a great replacement. If all your shooting for is maybe 425 hp . Maybe a turbo for a 435hp E model.
    Wheeljack and AModelCat Thank this.
  5. AModelCat
    164,656
    Afraid to ask what one would be worth from Cat. Borg Warners any cheaper?
  6. wore out
    wore out Numbered Classic
    17,324
    215,155
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
  7. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Cheaper, and better as far as I am concerned. I put the waste gated one on mine, where most of the guys here run the non waste gated one, and got exactly what I wanted. I was not really after a lot more boost, but wanted it to spool up faster and at lower rpms. I am happy as a clam with it runs.
    Shawn2130 and wore out Thank this.
  8. wore out
    17,324
    215,155
    Jun 5, 2013
    Share the part number with him. The waste gated one covers a sorta broad spectrum
    Shawn2130 and Wheeljack Thank this.
  9. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I will see if I have it written down somewhere, the turbo is on the truck I wrecked, and right now it is a pain to open the hood. lol. they did finally send someone out for pictures and the insurance company should be deciding what is going to happen with it. Hopefully I will be able to pull her in in a week or so and get started on it.
    It is the common one that everybody recommends for everything from the b model 425 to the 550 e model.
  10. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,900
    Sep 20, 2015
    Southern Ontario
    Hmm I wonder.... a waste gated E model turbo on a B model....
    I’ll have to speak to my boss about that.
    I’ve already told him that we should try an ACERT C15 compound on a E model.....
  11. wore out
    17,324
    215,155
    Jun 5, 2013
    It works....a Borg Warner 177148 will bring a B right to life...if it's set right
    stwik, Oxbow and Shawn2130 Thank this.
