Turbo Wing's Effect On Milage?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Disturbed Canuck, Apr 10, 2009.
  1. Disturbed Canuck
    Disturbed Canuck Light Load Member
    111
    5
    Mar 13, 2008
    Saskatoon, SK
    Can a wing on the roof of a flat top increase fuel millage significantly while hauling dry vans?
    Anyone have any experience with one of those things? The sellers of course tell me the highest numbers they know of...anyone have any real numbers for me?
    Cheers
  3. Big Don
    Big Don "Old Fart"
    17,996
    35,644
    Sep 8, 2007
    Utah's DIXIE!
    I can't give you any first hand info, other than an observation. One heck of a lot of big trucking companies do something of the sort. They wouldn't be spending their money if they didn't see a return on it.
    Of course the best answer, probably, is to buy the full fairing for the tractor when you buy it new. . .
    (But then not all of us can afford to buy NEW. . .)
    panhandlepat Thanks this.
  4. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    What kind of truck do you have?
    I've got one on mine, when I was pulling a van it made a difference but its always been on the truck, the most I do is raise or lower it. I gained around 1mpg just by raising it up to push the air over the front of the trailer.
  5. Hyper
    Hyper Light Load Member
    247
    135
    Nov 28, 2008
    Kingwood, Tx
    It does work well for mpg...but also is very effective for creating truck stop envy. "There goes a REALLY fast truck"
  6. Disturbed Canuck
    111
    5
    Mar 13, 2008
    Saskatoon, SK
    Well I give myself a top running speed of about 105Kph (about 65 Mph) so I guess that speed envy would only translate into when I'm parked hahahahaa.
    I have a 2000 Western Star with a CAT....3206 I think? Hmm....I was standing on top of that engine yesterday looking right down at that label and STILL I have trouble remembering that number. Despite the reliability of my engine, (It's frickin' bullet proof) it's a thirsty kitty and pulling a flat wall behind me doesn't help. I also only have a 48" sleeper so I can't get the van as close to the cab as I would like in most cases.
    A mile per gallon? Yowza. If I run 10,000 miles, that's a savings of tens of thousands if I can achieve the same! You sure you were doing your figurin' right?
    Good answer actually you're quite right. Many company fleets have the wings on their trucks if the sleeper doesn't come up all the way or if the truck is a flat top. Hmm...ok then. That's a good thing to think of.
    As for buying the faring on the truck new...Well I guess I'm about 9 years too late and tens of thousands of dollars short hahahaha.
    Cheers
  7. Disturbed Canuck
    111
    5
    Mar 13, 2008
    Saskatoon, SK
    Second question that comes up here. Can anyone tell me a Canadian dealer that I might want to get it from?
    Cheers
  8. oneshot
    oneshot Medium Load Member
    626
    248
    Feb 28, 2009
    mississippi
    I put one on my 06 W9 with a C 15,13spd,336 rears and 72 aerosleeper.I went from 6mpg to 6.4 running same trips at 65 mph. At that speed I'm turning 1300 rpm. That seems to be the sweet spot. Hope this helps.
  9. Red Fox
    Red Fox Road Train Member
    1,316
    432
    Jan 26, 2009
    Acworth, Ga.
    Canuck: stand in the back of a pickup truck on the interstate, and hold a 4x4 piece of plywood at an angle with the edge on the roof of the truck.
    Then step back a bit and hold it flat to the wind.
    You'll find out.
    Hoo Lordy I'm inna good mood tanite!
  10. Baack
    Baack Road Train Member
    15,294
    10,174
    May 24, 2007
    Wisconsin
    I googled the question
    And from what I could find out with out linking
    2 to 4% increase in fuel economy
  11. Disturbed Canuck
    111
    5
    Mar 13, 2008
    Saskatoon, SK
    Thanks for the theoretical comparative analysis idea there Red Fox. It sounds like an intriguing experiment but frankly, I prefer not to carry out tests which may result in my becoming forcibly amorous with the asphalt. :D
    Cheers
