Turbo
Discussion in 'Experienced Truckers' Advice' started by Redliningit2021!, Nov 25, 2021.
  1. Redliningit2021!
    Redliningit2021! Bobtail Member
    20
    26
    Sep 22, 2021
    CN you elaborate on the many other things other than it being illegal.
    Rideandrepair Thanks this.
  3. AModelCat
    165,366
    If you're buying a Series 60, it'll already have a turbo on it. Unless you're buying an engine out of a wreck in which case there's other items I'd prioritize checking/replacing long before the turbo.
  4. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Wiring harnesses, ECM, possibly need different engine mounts. Not saying it couldn't be done but putting a different turbo and starter on would be the easiest part.
  5. Redliningit2021!
    20
    26
    Sep 22, 2021
    Ok, I really appreciate it.
  6. Redliningit2021!
    20
    26
    Sep 22, 2021
    Ok I appreciate it. The guy said he has done several and the mounts would fit it. Just trying to see about how much I would be looking at if he has to do all what he said has with the turbo mounts,starter, and harnesses. Thanks a lot.
  7. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    If you're talking to somebody who has done a few of them that's who I would be listening to. A turbo and a starter won't add up to nothing really.
  8. Redliningit2021!
    20
    26
    Sep 22, 2021
    Ok great, thanks a lot.
  9. Magoo1968
    Magoo1968 Road Train Member
    2,066
    5,500
    Mar 18, 2021
    St Malo mb
    Do you want A/C in truck ? How about gauges? Cruise control? Exhaust system? Power steering? How about AIR compressor? You’re dealing with two different systems so you need to pay to adapt each component to work on the former DD13 equipped truck. More often than not it’s well over 10.000 if you have a good motor. A engine sitting under the hood is the easy part.
  10. Rideandrepair
    17,583
    56,952
    Aug 8, 2015
    Plenty of 2015 Gliders with 12.7s installed. It’s very possible. Get with the mechanic that’s done them. Sounds like he’s an expert on what’s needed.
  11. Magoo1968
    2,066
    5,500
    Mar 18, 2021
    St Malo mb
    Sounds like op doesn’t believe mechanics estimate of what’s needed to make it work.
