Turn Signal Problems with new LED bulbs
Discussion in 'Western Star Forum' started by PAUL301, Aug 1, 2017.
  1. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    Anywhere you can make them work. I never used them, so I have no working experience with them. Good luck.
  3. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Like others have said. You can't find the relay because there isn't one.
    You have to put a resister in line so there is a draw when you put your turn signals on. Mine are in the front turn signals on the front fenders. You wire in a resister between the red hot wire for signal light to ground. 150 ohm resister should do it.. One on each side.
    That will provide enough load on the circuit to make everything work correctly or make the ecc happy.
    Or just put normal lights back in
    Cetane+ Thanks this.
  4. flood
    flood Road Train Member
    4,169
    4,053
    Dec 25, 2010
    that's a bad ground
  5. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    It's not a ground. That system does those funny things it's not meant to be run with leds. He needs resisters or put stock lights back in .
    I have 2 westernstars been thru all this with exact symptoms
  6. PAUL301
    PAUL301 Bobtail Member
    6
    I went and bought some resistors yesterday. I'm going to put one before each set of lights i.e. The center panel and one before each mud flap hanger. Do you think that will help this issue??
  7. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    If you put an incandescent bulb in the circuit and they suddenly work again.... then yes it needs a resistor.
  8. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    All you need to do is take the lens off front turn signals on each side of fenders.
    Put a resister on the red hot wire going to turn signal and put other end of resister to the ground wire .
    Do the same for the clearance light circuit.
  9. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    If you buy the factory led front tune signals from western star they have the resisters wired in already just for that reason
  10. Star4900
    Star4900 Medium Load Member
    607
    521
    Mar 16, 2015
    Northern Ontario
    You need an LED module.....the one behind the tach and speedo in the dash that operates the turn signals and daytime running lights. Otherwise you have to wire an incandescent bulb in that circuit somewhere.
    My truck did not come with LED turn signals and I put a set on when the originals rotted out. They did not work. Dealer told me that I either needed to buy a module for LED's or add an incandescent in somewhere.
    Just wish they told me that BEFORE they sold me the LED turn signals and replaced that module under warranty when it failed.
  11. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    Here's a completely different way to get led turn signals without the troubles mentioned above. Last summer I changed all the lighting in our holiday trailer to the plug n play led bulbs. Had a couple left over. Decided to try them on the star front turn signals. Work great. Give the nice bright crisp flash. No mods needed. Plug n play.
