Turn signal relay
Discussion in 'Volvo Forum' started by Jdringg, Dec 17, 2014.
  1. Jdringg
    Jdringg Bobtail Member
    Turn signals don't work but hazards do. tractor unhooked. Only the fuses are listed under the cover and owners manual does not list them either. 2003 vnl64t any help is appreciated thanks
  3. FuzzFace2
    FuzzFace2 Medium Load Member
    417
    137
    Jul 27, 2014
    Angier, N.C.
    I know on a lot of cars use 2 flashers: 1 for 4way and 1 for turn signals so 1 could work and the others not like you have going on.
    Does the owners man. say where the flashers are and maybe swap them around to see if that makes them work.
    I could be all wrong too?
    Dave ----
  4. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    They have Only One Flasher And Its Located In The Fuse Panel U Do HAVE Two Separate Fuses FOR BOTH SIGNALS LEFT AND RIGHT U HAVE THE COVER IN FRONT OF FUSE BOX THAT ACT AS A FOLD IN CUP HOLDER REMOVE THIS COVER AND IN THE BACK U HAVE MORE FUSE DIAGRAMS AND FUSE NJ BEARS POSSIBLE MAXI FUSE BURNED AND NEITHER ONE IS GETTING POWER THAT WHERE I WOULD START CHECK THIS FIRST MAKE SURE YOU'RE GETTING POWER AT THOSE FUSE THEN IF U DO POSSIBLE FLASHER IS BAD BUT UNLIKELY IF HAZARDS WORK
