Turn signal stuck ON
Discussion in 'Kenworth Forum' started by MarioAtLandstar, Nov 3, 2020.
  1. MarioAtLandstar
    MarioAtLandstar Bobtail Member
    10
    OK, so I have a 2007 T600 and the right front turn signals are stuck On. The arrow on the dash is also on. The lights and arrow are on even with the truck turned off. The left side is fine and the rear left and right also are working normally. I have disconnected all the turn signals, checked and changed the pigtail (corroded but fixed),checked fuses and still no change. The arrow on the dash and the lights go of if I pull the fuse. I'm getting constant power to the right turn signals and the pigtail. I can't find the relay or anything else that pertains to the turn signals in the dash looked all day.. ‍♂️ please Help
  3. AModelCat
    165,067
    If your fuse panel is located behind the clutch pedal area, I'd lean towards a short in behind the fuse panel, causing the turn signal circuit to power up before the fuse. Could pop out the other fuses one at a time to try and narrow down what circuit might be the culprit. May even have to take the fuse panel out and check in behind it to see if any wires have rubbed through.
    @Goodysnap @spsauerland any other ideas?
    Sirscrapntruckalot Thanks this.
  4. Sirscrapntruckalot
    I can't help you with fixing the turn signal...see the post above for such advice, they know what their talking about. Anyhow...
    You will til you get it fixed be the one person on the road who uses their turn signal all the time, downside...your also going to be the ####### who has his blinker on for 70 miles and hasn't turned yet.
    Just think, you will make people happy, and want to kill you, all at the same time.
    Humor, it makes everything better, including stuck turn signals.
    Sirscrapntruckalot - Boxing Day...how Canada trolls the US.
  5. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
  6. Goodysnap
    Goodysnap Road Train Member
    3,778
    9,212
    Jul 12, 2017
    Does the light and indicator go out when you unplug the turn signal switch?
    Without testing my money is on a shorted/ stuck contacts in side the turn stalk.
    Dave_in_AZ Thanks this.
  7. MarioAtLandstar
    10
  8. MarioAtLandstar
    10
    I haven't gotten to it yet. I will try today and let you know.
  9. MarioAtLandstar
    10
    I have the fuse box open and looking in the back for anything that could be loose or touching.
  10. MarioAtLandstar
    10
    So just found and disconnected the turn signal switch and nothing changed..
  11. MarioAtLandstar
    10
    A anyone know where I would find the relay. I'm neck deep in to the dash and can't find it..
