Turn signals not working
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tayus, Feb 6, 2016.
  1. tayus
    tayus Bobtail Member
    18
    10
    Feb 4, 2012
    Windsor
    None of my turn signals work. So I proceeded to check the Junction box on the rear of the tractor. When I use a test light, I touch one of the wires and they start working. This has got me really confused. I've cleaned and used electrical grease on all connections but can't figure out the problem
  3. 59MackB61
    59MackB61 Light Load Member
    196
    165
    Sep 12, 2012
    If you ground it with a test light and it works than I would check the ground connections. Do they work on t he tractor?
  4. MooneyBravo
    MooneyBravo Heavy Load Member
    864
    1,257
    Feb 20, 2012
    Vermilion, Oh
    Check the blinker fluid reservoir
  5. tayus
    18
    10
    Feb 4, 2012
    Windsor
    Problem solved needed a LED flasher
  6. Pedigreed Bulldog
    7,737
    14,425
    May 7, 2011
    ...so the problem first occurred when you switched from incandescent bulbs to LED? That sort of info should have been included in your 1st post...otherwise, nobody would've guessed that. I was under the assumption that they were working and quit...and that you were trying to figure out what had happened, NOT that you were modifying things and messed up somewhere along the way.
    Good help requires good information.
    59MackB61 Thanks this.
