Turning down heavy specs
Discussion in 'Canadian Truckers Forum' started by Abovealltrucking, Nov 15, 2020.
  1. Abovealltrucking
    Abovealltrucking Bobtail Member
    Does some one has experience with heavy spec truck (detroit 16 motor with 550 hp) lowering to 500 hp and decreasing gear ratio?
    By doing this, was this heavy spec truck started giving normal highway tractor mileage ? Or was it still burning fuel like a heavy spec truck will?
    any feedback appericiated.
  3. Phantom Trucker
    Phantom Trucker Medium Load Member
    379
    682
    Jan 11, 2016
    Calgary, AB
    Hard to say if that’ll solve your fuel milage problem. One thing is for sure, switching out rear end gears will cost more than it’ll ever save.
    There’s other contributing factors you could look at as well, the wrong type of tires for your application can be a fuel milage killer. Engine components like a leaky air to air, valves out of adjustment, injectors, etc, aren’t good either.
    What are you getting for MPG? And is it that number actual miles driven divided by gallons added or are you getting that number off the dash?
    Also, can you provide some details about your operation? Type of truck, trailer, weight, part of the country you run in etc. (Your milage might not be too far from the norm).
    Cat sdp and 650cat425 Thank this.
  4. AModelCat
    163,805
    Why neuter a truck meant to do work?
    Buy something that's already setup for what you need it to do.
    mudflap77 and Cat sdp Thank this.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Just run it at the speed it is geared for and it’ll do fine.
    I regeared a truck once, cost me $5,000 and only saved 0.3 mpg
    BigHossVolvo and Phantom Trucker Thank this.
  6. mudflap77
    mudflap77 Heavy Load Member
    864
    1,314
    Oct 11, 2010
    South western Ontario
    How much of a change in gear ratio?
  7. uncleal13
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    4.10 to 3.58
    mudflap77 Thanks this.
  8. mudflap77
    864
    1,314
    Oct 11, 2010
    If that .03mpg took you from say 5.5mpg to 5.8mpg @ $3.00 fuel over 100,000/yr, you would be saving just shy of $2500/yr.. so a 2 yr payback.. Not a total waste of money as long as you keep the truck past 2 years.
    uncleal13 Thanks this.
  9. Marmon110P
    Marmon110P Light Load Member
    192
    189
    Feb 24, 2019
    Theres lots of proof out there that a driver can make up to as much as 30% of the fuel economy of the truck. If you dont know how to drive it, then your costing yourself more $$. I suspect that if you think turning down the HP on an engine will help fuel economy, then your not gonna get good results no matter what you do...
