Turns hard
Discussion in 'Freightliner Forum' started by HNTowing, Nov 7, 2019.
  1. HNTowing
    HNTowing Bobtail Member
    I have a 2011 Freightliner M2 Flatbed. The problem I'm having happens driving or parked. When turning the steering wheel it goes from hard to easy back to easy about 4 times per rotation of the wheel. it doesn't matter what direction. I'm assuming it needs a steering box but not sure. Thank you for your help
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    When was the last time the power steering fluid filter was changed?
    baha and x1Heavy Thank this.
  4. AModelCat
    165,007
    4 times per revolution? I'd check your steering column u-joints. Could be binding up.
    magoo68, QUALITYTRUCK and Roberts450 Thank this.
  5. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    I would suspect the pump and or filter first.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    5th wheel grease?
    Power steering pump and be quick to check it. Don't ever run that dry. Its VERY expensive.
    dibstr Thanks this.
  7. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    You hit the nail on the head I believe.
    x1Heavy Thanks this.
