TV antenna recommendations?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Iampa, Oct 24, 2021.
  1. Iampa
    Iampa Light Load Member
    167
    659
    May 4, 2021
    Henderson NV
    I've got one of those Walmart $20 flat hd antenna and it just isn't doing the job. Some places it's give but I think I need a better amplified model.
    Anyone got recommendation?
    Also, anyone set up an outdoor version?
  3. tarmadilo
    tarmadilo Road Train Member
    1,731
    4,771
    Dec 12, 2018
    Try the antenna for your FM radio, the frequencies are very close.
  4. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    it's not the antenna... even a old set of rabbit ears will work.... the problum is that the change to digital required the signal power be cut back....
    You need a high power signal booster (over 20db) to get a good signal on the truck...
    Like this
    https://www.amazon.com/CIMPLE-CO-Di...B00DQN3R9O,B07Y5PVDF7,B07XZ6MKJ7&srpt=ANTENNA
    Iampa Thanks this.
  5. The_vett
    The_vett Medium Load Member
    555
    2,766
    Jan 8, 2021
    So Cal / PNW mostly
    Try an RV roof antenna , they work great.
