twin stick ratios
Discussion in 'Experienced Truckers' Advice' started by rank, Apr 18, 2014.
  1. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    Anyone know where I can find the ratios for different types of twin stick transmissions 4x4, 6x4 etc? Are they all Spicer except for Mack?
  3. wore out
    wore out Numbered Classic
    17,537
    219,102
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Most of them are spicer. Do a search on here Pack Rat TDI posted the ratio's on a couple several years ago. A google search on spicer will get you some as well. I just bought a new 1750 from TTC there were 3 different ratios on that box alone.
    PackRatTDI and rank Thank this.
  4. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    Cetane+, rank and wore out Thank this.
  5. rank
    9,919
    113,510
    Feb 11, 2010
    yeah there was some good info in that thread. Thanks. I found some good discussion with the search tool but didn't see that one.
    I have a 1998 T800 with an M11 Cummins, 13RTLO, 4.33 rear gear, 22.5 Lo pro rubber. I routinely gross 75,000 - 89,000 through PA so I have some hills and the M11 needs that 4.33 rear gear. Problem is half of my miles are grossing 30,000 - 50,000 and I an screaming along at 1800 rpm at 60 mph.
    IFTA reports show me doing ~ .75 mg better than the big motors in our fleet doing the same runs. I have tracked fuel mileage at 70, 65, 60 and 55 mph and I still haven't found the point where teh mileage levels off.
    I think I could use another overdrive gear. Would one of these boxes fit the bill or should I be looking for a 13RTOO?
  6. rank
    9,919
    113,510
    Feb 11, 2010
    What did that cost?
  7. PackRatTDI
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    Yeah it took me a while to find it and I wrote the #### thing, lmao.
  8. PackRatTDI
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    I'd suggest adding the brownie box due to the fact the RTOO boxes can be really hard to find.
    Plus you'd gain an extra starting ratio or two.
  9. rank
    9,919
    113,510
    Feb 11, 2010
    OK...googling brownie boxes now. Search returned lots of cookies LOL.
  10. PackRatTDI
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    Probably look it up under TTC like wore ou
  11. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    We used to flip 1 of the gears in the RTO's and make generic RTOO. Can't remember just how we did that, but my old 359 would stroll with that set up.
