Twisted straps were singing in the wind
Discussion in 'Expediter and Hot Shot Trucking Forum' started by rccarlson22, Sep 18, 2020.
  1. rccarlson22
    rccarlson22 Medium Load Member
    431
    761
    Aug 27, 2019
    Anything taller than about 3 feet gets a twisted strap on the trailer. Have never had an issue
    I ran two coils about 6 feet tall, chained them like normal but I threw a strap over the top because redundancy. However, the straps were still singing the whole ride. I put my whole 225lbs cinching them down.
    Any idea why? Should I have done an extra twist on them? Is there such thing as too much twist?
  3. D.Tibbitt
    157,927
    Half twist is all it needs . Even when they get loose the twist keeps them from vibrating. Not sure how or why it works but it does. Are u using 4inch straps .? Or smaller ?
  4. rccarlson22
    431
    761
    Aug 27, 2019
    Yes 4 inch straps. They had the half twist on each side
    singlescrewshaker and D.Tibbitt Thank this.
  5. okiedokie
    okiedokie Road Train Member
    14,162
    113,063
    Jun 13, 2011
    PNWET
    Straight straps act like an airfoil. Hence vibration.
  6. rccarlson22
    431
    761
    Aug 27, 2019
    Yeah I had them twisted and I cranked them down with everything gravity and me could give. They were still flapping
  7. okiedokie
    14,162
    113,063
    Jun 13, 2011
    PNWET
    Well you were going at highway speeds so yeah they still vibrate sometimes even twisted.
  8. MericanMade
    MericanMade Heavy Load Member
    776
    1,811
    Aug 14, 2019
    Pensacola, FL
    Too many twists will vibrate IME. I almost majored in aerospace engineering, but switched to systems engineering, so beyond that tidbit, I can’t help you.
    rccarlson22 Thanks this.
  9. D.Tibbitt
    157,927
    Were they at an angle ? U said u secured a coil with them so u put strap directly across the rub rail or was it more diagonal across the coil?
    rccarlson22 and singlescrewshaker Thank this.
  10. singlescrewshaker
    4,933
    43,356
    Dec 31, 2017
    Little Havana, FL
    Did you make sure the c shape of the twist is facing forward, ie into the wind.?
    If the u shape is forward it will scoop the wind & vibrate..
    When I put a half twist, put a click our 2 on the winch. Manipulate the strap by hand so C is into the wind, then give'er..
    Zoom in, can see the rounded edge forward on all but the 4th one from the front.. I missed one, but low enough it didn't matter..
    rccarlson22, Xray4 and D.Tibbitt Thank this.
  11. rccarlson22
    431
    761
    Aug 27, 2019
    No angle, the strap went over the tallest point of the coil, in line with the center hole. I ran it inside the rub rail.
