Two CB radios... one reaches, the other doesn't.
Discussion in 'CB Radio Forum' started by Smaggs, Apr 6, 2020.
  1. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    I have two radios. I bought a DX2547 base back in 2006 and a DX979 mobile in 2011. I had both "peaked and tuned" Nothing clipped or bent. Just had a shop read them with a scope and bird meters to make sure they work and to make sure they weren't splatter boxes.
    Well I've had the base radio in storage for a long time in my house. Just too busy working to use it. I got it out, because I'm off work due to the whole Covid 19 situation.
    Here's the issue. My DX979 mobile radio really reaches, and my base station does not. My power meter really swings when I talk on the 979 and it doesn't move one bit when I read it on the base.
    Had my girlfriend talk to me while I drove over five miles away. She could hear me like I was close, but I could only hear her when I was less than two miles away. Both radios have roger beeps, which those seem to punch through, but not her voice.
    Same results if I switch radios in the house on the antenna on my roof... or if I switch radios in the car. So if I take my radios out and talk to someone on my mobile, they hear me great. If I swap for the base radio in my car with the same mic and antenna, it's like nobody can hear me. If I do the same test in the house... my mobile radio reaches for a little over 5 miles. There's a guy in my area with another base setup and I was checking with him. As the crow flies, we are almost 9 miles apart, but there is almost no obstruction between us. If memory serves, he uses an Antron 99 with ground plane kit that fits it.
    I checked my variable resistors. My modulation is maxed (I double checked with a hand held Uniden radio to see which way is up and down on the pots). My AM low and high power pots are good. It's just like this 2547 isn't really working and isn't even hitting 4 watts. That's really annoying, because I paid over $300 for the base radio, but I can only talk for a mile before the signal fades.
    Here are my setups.
    For the house: 100' of RG8x coax. I temporarily have a wilson 2000 series antenna with a ground plane on my roof. I get less than 1.5:1 SWR. I have an Antron 99 antenna on back order. I used to have one, but must have lost it when I moved from Arizona to Pennsylvania.
    For my car: Magnet mount Stryker SR10A antenna with RG8X coax. Same SWR readings. Super low.
    If I put my DX979 on either setup, it really reaches. One local guy asked if I was using an amp, which I do not. I also use Ranger SRA 198 microphones. They're clear and passive noise cancelling.
    I hope this info makes sense and hopefully I can gain understanding as to why a base radio with all this extra crap in it seems useless. It's basically a DX959 in a base case. Maybe I got unlucky and got a hunk of crap for hundreds of dollars?
    Side note: I have a 20 amp 12 volt power supply. I might just buy another 979 for my car and use my old one as a base and get rid of the 2547.
    Any suggestions would help. Has anyone else had trouble with a 2547? Has anyone had positive experiences with a 2547?
  3. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    I tried one more thing with each radio and maybe this will shed a little light?
    DX2547: PWR position for the meter. If I key up it sits around 3 and barely moves toward 4 when I talk at 100% modulation.
    DX979: PWR position for the meter. When I key up it reads around 4 and swings to around 18 when I speak at 100% modulation.
    I'm wondering if this means I'm getting plenty of modulation with the 2547, but the carrier power is low for some reason.
  4. Night Stalker10
    Night Stalker10 Road Train Member
    1,699
    1,271
    Jun 26, 2017
    I'm not sure what you mean by checking variable resistors. I assume all this testing had been done on AM only? Have you tried the SSB mode?
    Smaggs Thanks this.
  5. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    There are variable resistors (VR14, VR16, and VR18) one is for modulation, one is for low AM Power and the third is for High AM Power. I checked them to be sure they worked and they do. I just get almost no movement on the power meter when I key up. Modulation is high, but power is non existent. I transmit at normal volume, but only for a ridiculously short distance. My DX979 goes for miles on the same microphone, coax, and antenna.
  6. Ridgeline
    22,774
    124,532
    You need an alignment for the base, the tech who checked it didn't do his job.
    And please get rid of the 8x, replace it with 8 or 213 or go all out and put in hard line.
    rabbiporkchop and Smaggs Thank this.
  7. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    I will look into this. I never heard of 213, but I did a search and I see that 8x seems to have a lot of loss and is thinner.
    I'll look around and see where I can get a proper alignment and hopefully be able to post my results.
  8. Night Stalker10
    1,699
    1,271
    Jun 26, 2017
    Oh okay, I thought maybe you were referring to the trim pots but I wasn't sure. I guess most techs refer to them as pots, since it's easier to say then variable resistor LOL, although technically that is what they are.
    Unfortunately it sounds like the DX2547 needs an alignment for some reason. I use RG213 for my base radio and RG8X for my mobile and it works fine for me.
    Smaggs Thanks this.
  9. Troy McClure
    Troy McClure Bobtail Member
    7
    6
    Apr 2, 2020
    You need an external power meter so you see exactly how much wattage each radio is doing AVG and PEAK. The Galaxy 2547 has same board as the 959/949 mobile which have no problems getting heard (although they are known to drift on SSB).
    The 979 board is different than the 959/949/2547 but it shouldn't be a whole lot different on air if all things were tuned equally.
    You may also want to try switching mics - just because you use the same type of microphone on two radios, doesn't mean that each microphone is working exactly the same.
    You mentioned the variable pot for modulation - are you sure you turned it the right way?
    The low pot you adjust when the variable is all the way down to set for a 1 watt or so deadkey for low power output, the high pot is for when RF power is in the max position for a 4 watt deadkey.
    It sounds like the radio needs to be tuned again, I'd talk to your tech, or maybe a different one if he screwed up :)
    Smaggs Thanks this.
  10. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    I decided to get another 979, and I'll use my old one in place of my base radio for now. I'll get my radio into a shop when I can find one that can take it. Hopefully, I'll get my answer, but for now I have to wait.
  11. Powder Joints
    8,041
    8,513
    Sep 25, 2007
    Rosamond, SoCal
    You just need to have a tech align your radio, first things first. RG213 or 214 are good, but take care of the radio before you spend more money on stuff.
