Types of Axels
Discussion in 'Questions From New Drivers' started by cbones98, Sep 17, 2022.
  1. cbones98
    cbones98 Bobtail Member
    15
    18
    Jun 21, 2022
    Lift axels, drop axels, pusher axels, tag axels? I have a general idea but I could use some clarification on each and what purpose they serve. Are lift and drop the same things just different name?
  3. Gliding ProStar
    Gliding ProStar Heavy Load Member
    860
    6,132
    Nov 12, 2016
    Waxahachie, Texas
    Lift axles and drop axles are axles that can be raised or lowered to support the weight you are carrying.
    A tag axle can be stationary or be a lift/drop axle. A tag axle is an axle that is not driven by the driveshaft. It is just a weight supporting axle. These types of axles are commonly found on 6x2 trucks.
    A pusher axle is commonly used in buses and RV's. It is the rearmost axle and it is used to push the vehicle.
    cbones98 Thanks this.
  4. wis bang
    wis bang Road Train Member
    3,458
    4,107
    Jan 12, 2011
    Levittown, PA
    Fleet operator for Chem Leaman set up his macks as single axles with an air lift tag instead of a tandem drive.
    Returning MT to home they lifted the tag axle and and paid 4 axle tolls instead of 5.
    The lift allows you to vary the load on the tag axle.
    That guy paid hub miles based onthe average of 3 trusted trucks till they caught one having breakfast a the dinner while the fully inflated tag held the driven wheels in the air turning the hubometer.....
    Siinman, Capacity, D.Tibbitt and 2 others Thank this.
  5. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    My dad had a U model with one. If you got off road in the mud just lift it up and it'll keep going but you really won't be able to steer it lol
  6. cbones98
    15
    18
    Jun 21, 2022
    Right on, thank you So a tag axel refers to a non drive axle on the cab whereas drop/lift axels would be on the trailer right?
  7. Blu_Ogre
    Blu_Ogre Road Train Member
    8,497
    50,784
    Jul 14, 2013
    Out west
    The way it was explained to me:
    Lift axles = an axle in a trailer axle set that can be lifted to enhance maneuverability and lower tolls and fuel consumption when light. Default is axle down.
    Drop axle = non powered axles in front of drive axles that can be raised when the extra weight capacity is not needed. Seen a lot on dump trucks.
    Tags are like a drop axle but behind the drive or tandem. also seen on a lot of dump trucks.
    Pushers are mounted behind the drives and are typically not able to be picked up. Cheap way to turn a single screw day cab into a tandem axle day cab.
  8. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    Tag axle is on The back of trailer behind tandems, it "tags" along. Pusher would be in front of drives on truck. It gets pushed along. Both would lift. 20200824_092943.jpg
    cbones98 and singlescrewshaker Thank this.
  9. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    Lift, tag, pusher, 3rd axle. I've heard em called almost everything.
  10. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    Pusher is a non drive axle in front of the drive axle. Tag is called tag because it tags along behind the drive axle. Pusher is in front.
    To op tag and pusher refer to axles on the truck. Typically tag axles aren't lift axles, but they could be, like on a straight truck. Lift axles in front of the drive axle(s) are called pusher.
    singlescrewshaker and lester Thank this.
  11. motocross25
    motocross25 Road Train Member
    3,889
    11,949
    Sep 23, 2010
    Overland Park, KS
