U-Joint wont purge grease - should I replace it or keep dealing with it?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by CountryBumkin, Nov 3, 2021.
  1. CountryBumkin
    CountryBumkin Bobtail Member
    43
    39
    Jun 4, 2018
    I have the Spice 1710 series u-joints (the style with the bearing cap). This is the second time I've run into this issue where two of the four bearing will not purge grease. last time (and per Spicer manual) I had to press one bearing cap out slightly (about 1/16 or so) then grease would flow out of all the bearings.
    According the Spicer service manual, this is to be expected. But it's a huge pain the but to get those bearing caps loosened up. Hard to access due to other components located under the joint area.
    For now I'm going to press the bearing cap out slightly and grease. This adds an hour or two to an otherwise simple grease job. Spicer U-Joint servicing.jpg
    So, would you recommend replacing this u-joint or just keep dealing with it as I am doing now?
    If I replace the joint, will I just have the same problem with the new one?
  3. Old dirty trucker
    Old dirty trucker Bobtail Member
    41
    47
    Oct 24, 2021
    In the past I've had the same issue, I would get the correct size hose clamp and a piece of rubber or plastic bag. Place around where the grease first escapes, then put on hose clamp and lightly tighten and lay the grease to it. Worked well for me, I like to see grease at all 4
    Rideandrepair Thanks this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,779
    9,212
    Jul 12, 2017
    I agree it is nice to see grease purge all 4. The SPL series seem worse to purge to me and always purge fully on 2 only. Most cases you can see the grease slight on the 2 that didnt flow thru. Never seen one fail that was lubed regularly. I hit them good and let them roll and never an issue. Loosening the caps seems excessive, and replacing because they didnt purge is definitely excessive as the new ones will repeat just the same.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,555
    6,643
    Aug 26, 2014
    2nd.
  6. lester
    2,957
    8,088
    Jan 2, 2012
    NW, Iowa
    I've never worried about grease purging from every cap. Heck I don't even hit both zerks, just the first one I see. As long as you get grease in the u joint it will work its way to the caps when its spinning 9000mph and gets warm. Speaking of warm I think it best to grease when it's warm, as in just came off the road
    Dino soar and Rideandrepair Thank this.
  7. mtoo
    mtoo Road Train Member
    1,942
    4,526
    Jan 15, 2011
    Retired on bended knee
    I never worried about it either. I just used a good quality grease and greased often. Millions of miles and no problems. Just get the truck rolling like you know what your doing.
  8. Lazer
    Lazer Road Train Member
    1,850
    2,983
    Jan 22, 2017
    That’s why I use a manual grease gun, with the handle. As soon as I hear/see the grease stretching the rubber seals, I stop. I don’t like to see grease on the undercarriage splattered where every ujoint is.
  9. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    Anytime they’re loosened, they suggest replacing straps and bolts. I doubt it’s really necessary, but maybe suggested for a reason. I’ve got one now that I reused them on about 100k mikes ago. Maybe a little medium Locktite? I’ve replaced quite a few u joints, without using a torque wrench. Till I somehow ended up with a broken bolt on the yoke, after a few thousand miles. Must have over torqued it, or straps had slop. I don’t know. Now it’s torque wrench only, after having to have a new yoke welded on. Reminds me, I need to replace the big nut on tailshaft, and install my new straps and bolts, I’ve been saving till I get the new bolt put on.
  10. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    If I replace the joint, will I just have the same problem with the new one?[/QUOTE]
    I wouldnt worry about it. I cant recall the last time I saw a ujoint fail that had regular servicing.
  11. CountryBumkin
    43
    39
    Jun 4, 2018
    They say if it is the "bolt only" type replace the bolts each time. If it is the bolt with lock straps, replace the strap each time. Mine is bolt with strap. I have a bag of the lock straps. For the cost of a couple of lock straps (like $1.00 a pair) why take the chance of loosing a cap. But I'll admit before I knew about Spicer's recommendation to always replace the strap, I reused the lock straps all the time.
    The last time I pushed out one cap for greasing I had to use a u-joint bearing removal press with my 1/2" impact gun, and even then it was tough going. Since this "my" vehicle I think I push out the cap one more time and thoroughly grease - but not waste my money buying a new joint (and end up with the same problem).
    Thanks for confirming that - and the other suggestions.
