ultrashift plus transmission issue
Discussion in 'Heavy Haul Trucking Forum' started by shmyreal, Feb 24, 2021.
  1. shmyreal
    shmyreal Bobtail Member
    43
    19
    Mar 12, 2017
    Hello,
    does anybody have any wild guesses why this happened?
    cke Thanks this.
  3. cke
    cke Road Train Member
    6,174
    76,029
    Aug 4, 2013
    Colfax Wi
    Hmmmmm it appears the bull gear jumped the heifer gear.
    Ruthless and singlescrewshaker Thank this.
  4. truckdad
    truckdad Road Train Member
    2,073
    17,165
    Dec 14, 2014
    Penn Valley, CA
    Did it happen "suddenly"? or had it been making noise for several days?
    Oxbow and cke Thank this.
  5. shmyreal
    43
    19
    Mar 12, 2017
    Yep, just went into neutral and that is it. No other signs. the truck has 150k miles only.
  6. AModelCat
    164,832
    She didn't go into neutral, you roasted the input gear!
    Andreybanyuk, Roberts450, cke and 2 others Thank this.
  7. truckdad
    2,073
    17,165
    Dec 14, 2014
    Penn Valley, CA
    I'm thinkin the driveline speed sensor and the engine speed sensor had a disagreement over something..............;)
    stwik, Roger McG, cke and 1 other person Thank this.
  8. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Low on gear oil for a bit is all it takes to wipe one out?
  9. Pal22g
    Pal22g Bobtail Member
    9
    6
    Nov 10, 2019
    hello Brother's
    I am looking to buy a 2016 volvo with ISX 15 and UltraShift Plus transmission , I am new to UltraShift Plus transmission. how are this transmissions ?? I am a bit scarred .. TIA for your input
  10. shmyreal
    43
    19
    Mar 12, 2017
    Hello Pal22g,
    it is good transmission until it breaks then you will have troubles. It has 5 sensors if one has an issue you can't move... In my personal opinion, I would not even look at ultrashift option even if somebody will offer free replacement. Downtime is my biggest concern!
