umbilical hernia
Discussion in 'Questions From New Drivers' started by ledzep, Feb 21, 2019.
  1. ledzep
    ledzep Bobtail Member
    Jan 3, 2019
    Got 2 year dot exam passed.but have umbilical hernia does not bother me. Is that make me unhireable for otr job.
    Rideandrepair Thanks this.
  3. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    No, not at all. I’ve had one for a few yrs now. DOT Dr actually advised against fixing it if it’s not a bother. Same with Dr I saw for a second opinion. I’m going to get it fixed eventually anyway.
  4. ledzep
    Jan 3, 2019
    thanks for the reply.was freaking out about it
  5. Ridgeline
    22,720
    123,248
    Freak out dude, I have one and it was said to get worst if you don't watch yourself picking up stuff. I ignored that advice until I met a forklift driver who has a specially made girdle because his split and he has half of his gut hanging out under the skin, they can't operate on him until he drops some weight and he has lost about 3 pounds since I met him four years ago - stubborn idiot.
    buddyd157 Thanks this.
  6. Moose1958
    Moose1958 Road Train Member
    15,291
    33,959
    Dec 17, 2010
    Williesburg, Virignia
    No! It does not! Take care of yourself and keep a close watch on this. Do your research on just what a hernia is. While there is medical reasoning that surgery is not required, it is possible to aggravate a hernia and in some cases be an emergency. Just pulling yourself up into the truck can damage it further. One of my uncles was near Little Rock and had a hernia going all the way back to the 50s. He was climbing up into the truck and damaged it further.
  7. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,163
    Jun 3, 2018
    I know a guy who had his hernia " fixed" they put in that mesh , his body rejected it he had tons of problems. He finally had it removed and now the only thing holding him in is the skin. Just below the rib cage in the center of his body it looks like a golf ball under the skin pushing out .
  8. ledzep
    Jan 3, 2019
    I just want to know if it is going to pevent me from getting a job.
  9. robinrene
    robinrene Light Load Member
    81
    59
    Jun 3, 2012
    Gypsy, USA
    Nope
    I've had one since the army. Had several physicals since then
  10. layover6
    layover6 Light Load Member
    65
    55
    Jan 25, 2014
    I had one for years all was well until a piece off fat got lodged In the hole then it was not so good All I did was puke ever time I ate until it was fixed
  11. Moose1958
    15,291
    33,959
    Dec 17, 2010
    As I said in my first post that answer is NO! However, depending on things it is important to remember as a trucker you are doing things almost every day that require the use of those muscles in your lower stomach. If you have a hernia, things, like pulling yourself up into the truck and raising and lowering the landing gear, can cause problems over time. Keep a close watch on the hernia and remember to be careful with any physical activity.
