Understanding A truck specs
Discussion in 'Ask An Owner Operator' started by blue1005, Aug 24, 2019.
  1. blue1005
    blue1005 Light Load Member
    157
    87
    Apr 18, 2015
    Hello, I am in no way a mechanical person. I am thinking about buying my first truck a
    2015 VOLVO VNL64T670
    Manufacturer VOLVO
    Mileage 454,040
    Engine Mfr Cummins
    Engine Type ISX
    Horsepower 450
    Engine Brake yes
    Transmission Manual Drive 6x4
    Axle Front 13200
    Axle Rear 38000
    Ratio 3.36
    Tire Size Doesnt say
    Wheel Base 219
    Wheels Aluminum
    GVW 52000
    Is This a good truck for fuel mileage, running as flat as I can but may need to take loads in mountain areas.
    What would be a fair estimate for MPG, Reliability of this year, and are those axle weights normal?
    ANY info you can give is really helpful. I appreciate all you offer as I am very new to this.
    IF this is a terrible POS, what is honestly better, I am looking for cheap to run and make money with it. I dont need shiny and loud, just reliable and good MPG.
    Hulld Thanks this.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Doesn’t say which transmission other than a manual.
    A lot of guys get around 7.2 mpg with that.
    3.36 rear ratio would do close to 1300 rpm with 11R22.5 tires at 65 mph
    FlaSwampRat Thanks this.
  4. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I have to wonder about those specs. I like a 6X4 , but you would never see one in a volvo, so they must have something else they are calling it.
    I would also think it would have 40s for rears, instead of 38s
    Up here that isx would have already have been rebuilt, but this country is hard on them, I don't know what kind of mileage they are getting on them down there.
  5. blue1005
    157
    87
    Apr 18, 2015
    I thought that too about the rears weight, that seems odd, But every volvo I am looking at says 38k. Idk why
  6. Liquidforce
    Liquidforce Light Load Member
    273
    287
    Sep 27, 2016
    Savannah GA
    Pretty common fleet spec truck, ISX of that age and mileage you’d want to make sure it had the fuel pump rebuilt.
    I’ve seen a fair few Volvo’s with 38klbs rears.
  7. 201
    201 Road Train Member
    12,820
    26,400
    Apr 16, 2014
    high plains colorado
    A 6 and a 4, (whistles), and I thought those days were over,,:biggrin_2559: Volvo? ,meh,, I suppose it's equivalent to like buying an old Schneider IH cabover years ago. It will work. Pete or KW, you'll be proud to own and you get resale when ,,oops, I mean, if you fail.
  8. Long FLD
    Long FLD Road Train Member
    12,958
    54,384
    Mar 4, 2015
    The truck is a 6x4 not a 6x2, it’s not saying it has a 6 and a 4 in it.
  9. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    With that kind of mileage things really start to go south on them. You want someone who knows the ISX to take a look at it and to see what are the common problems of that particular year.
    I have heard a lot of horror stories with people who own high mileage ISX, but I am not familiar with them.
    I would look over the engine, drivetrain, and the emission system to make sure everything‘s good to go.
    You could either spend the money on a warranty or you can bank that money and use it as your repair fund which you’re probably going to need in the near future
  10. DUNE-T
    DUNE-T Road Train Member
    7,058
    17,201
    May 10, 2015
    Detroit, MI
    Money pit
    Socal Xpress and Cat sdp Thank this.
  11. wore out
    wore out Numbered Classic
    17,431
    216,945
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    It's not a 6x4 trans mission. Its 6 wheel positions 4 that drive. Another words just like every other truck comes down the pipe
    BigCam9670, mslashbar, Cat sdp and 4 others Thank this.
  12. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    Looks like a good candidate for purchasing Cummins Encore XT1 second owner warranty. It’s $4500 for 2 yrs 200k and just needs to pass their inspection. They will make sure all the updates are done to it as well. I’d just make sure it passes Cummins inspection before you buy it.
    The truck will probably get around 7 mpg average depending on idle time and how well you drive it. Could go as low as 6.5 mpg
